That is a good reason for sure. Never considered that... makes sense.Iconfabul8 wrote:I believe another reason for the plywood in the ceiling is to keep from rubbing metal on metal and wearing holes in the roof.
shootr wrote:Simple pleasures, amiright?![]()
McDave wrote:shootr wrote:Simple pleasures, amiright?![]()
A men!
So, it may seem a bit overwhelming to build a bathroom and all the infrastructure etc. but really it was no big deal. But this is the time plan. I started out with the idea of just a tent on wheels that I could haul the Harley in. But after staying in the campgrounds at Sturgis and other rallys and experiencing the conditions at the community facilities I decided a garden hose at a gas station would be much, much better. Then my wife began to show some interest in going with me and I knew there was no way I could expose her to that kind of conditions. So my plans changed and I'm so glad they did. This made the trailer much more versatile and useable. I helped a friend who had a stroke move from a upstairs apartment to a house in the country this last week. He lives a couple hundred miles from us in the Beartooth Mtns.. When we got to the new place they were still working on the bathroom plumbing so it was out of order. No problem, I have one with me. Kind of a lifesaver for him and more justification that it was the right thing to do. It is a luxury of sorts but if that what it takes to have my wife go with me, so be it. I have seen some really clever set ups, but because I haul the Harley I only had limited space and options in a 6 x 12. So wet bath style uses less space and gets the job done. I only ran 1 water line from the tank (under floor, behind axle) to the pump then to the tee where 1 goes to toilet, 1 to instant hot water heater. To get warm water just adjust flame size and water flow controls on heater in shower. It has a wand with on/off control. The shower pan/ toilet combo has a floor drain and the toilet flange moulded in. Just mount black beneath and cut appropriate size holes in the proper location and plumb in with ABS and grommets. You can do this stuff, but you will need a plan to make things fit and work together. I'd say about 500.00 for all materials including kitchen sink and plumbing, tanks, pipes, pump, valves, shower pan, metal shower walls, toilet and heater and asst. fittings.
Good luck whichever way you go, if you need help just ask.
McDave
McDave wrote:Are you floating/kayaking on the Salt? Did that a few times in my single days. (tubers w/coolers)
McDave
shootr wrote:
Not sure if I'm completely ostracized from the forum, but I do want to thank you all for the responses and interactions. I am bummed I won't be able to create something unique, but stepping back and taking a big breath of reality, this is probably the best for us.
hankaye wrote:shootr, Howdy;
I've attached a link for you, it's a pre-acceptance check-list for RV buyers.
So many folks buy one (RV), and don't get the information on where things
are and how they are supposed to function.
Don't let them rush you through saying they are busy and can only allot you
so much time for this and don't sign anything or hand them the check until
you are satisfied that the trailer is acceptable to your standards. CW is notorious
for hustlin' folks through then charging $135.00 or more /hr to fix things after
they have accepted their RV.
Look at things like the chalking around the roof line and any thing that is an
install through the sides or roof.
If it looks like it has never been used then ask to see the title, they can move it
from one dealer to another and consider it 'used'. If they are doing that then they
can get around the 1 year warranty thing and sell you an 'extended warranty' for
a few thousand 'extra'. It's all about Markus Simones trying to take as many hard
earned $'s as possible from you wallet and stuffin' them in his.
The list is extensive and has been used and approved by many more then a few
RVers.
http://www.angelfire.com/trek/buenavist ... V113_2.pdf
Have fun, enjoy your RV, see ya around here.
hank (resident RV dweller and cynic)
