flboy wrote:Wow... That is really nice! Well done! I like it!![]()
Hader wrote:flboy wrote:Wow... That is really nice! Well done! I like it!![]()
Thank you!
What do you think the limitations or abilities of a 40W solar panel? We found one that was on clearance and bought only 1
flboy wrote:I could see it as being very useful to maintain your batteries when in storage. If you have a small battery and you want to use it for running a laptop or charging a phone, or running a few LEDS, at night, it may provide enough power for that if charging all day with good sunlight. I wouldn't expect too much from it.. just because of the size.
beachguy005 wrote:That's a lot of components to put up an awning.
[/quote]Are you thinking that the EMT, Tees and PVC pipes being 3 Components?
Once the EMT is inserted inside the PVC and the tees are glued it becomes 1 component.
Excluding the tarp and bungees, there's only 9 components (pieces) to handle for easy assembly and storage.
For others benefit, please post a photo of your awning.
beachguy005 wrote:Not so much about set up, just seemed like a lot of construction parts.
beachguy005 wrote:My comments aren't based on criticism or competition, only observation.
