Formica deco metal
Formica deco metal
Postby Woodbutcher » Tue Jul 11, 2006 9:53 pm
Has anyone used this Deco Metal by Formica on the outside of their tear?
http://tinyurl.com/l3szj
I can't find anything on the Formica website that says it can't be used outside. It does say that it will not bend sharper then 8" and is more dent resistant then the metal alone. The reason I ask is that one of my suppliers has damaged/reject sheets at 20.00 each.
Woodbutcher
Postby madjack » Tue Jul 11, 2006 10:05 pm
WB, we looked at a similar product(don't remember what brand) when we started our build, since they had all these wonderful textures and colors...then we found out it costs around 9 bucks a sqft :shock: :shock: :shock: so we stuck with mill finish Al....don't know about weather resistance but that is a heck of a price....
madjack 8)
Postby Nitetimes » Tue Jul 11, 2006 10:10 pm
That stuff looks pretty cool, the only problem I can see except for the possible UV thing is what do you do at the joints to make them water tight?
Otherwise it looks do-able. :thumbsup: :thumbsup:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Re: Formica deco metal
Postby Micro469 » Tue Jul 11, 2006 10:10 pm
Woodbutcher wrote:Has anyone used this Deco Metal by Formica on the outside of their tear?
Check the Data sheets on their website. Says its for horisontal or vertical interior use only. ;)
John
Micro469
Images: 382
Postby Woodbutcher » Tue Jul 11, 2006 10:31 pm
I did not see the interior use on the site. But I did see where it says it moves less then the metal alone does. As for how to deal with the seams, I am building a woody so I wanted to do just the roof with it. I could cover the seam with a wooden rib sealed and screwed down. Any thoughts? Unless the exterior exposure delaminates the metal to their backing I can't see what else could happen to it.
Woodbutcher
Postby doug hodder » Tue Jul 11, 2006 10:39 pm
At that price, whether you used it on the exterior of the tear or not...I'd get it...lots of things you can do with it in the future, and you could have a lot of fun with it while finishing out the galley.... :thumbsup: Doug
Postby Melvin » Tue Jul 11, 2006 11:21 pm
Nitetimes wrote:That stuff looks pretty cool, the only problem I can see except for the possible UV thing is what do you do at the joints to make them water tight?
Silicone sticks to formica pretty good, all you'd need is a cover strip of Al to prevet mechanical damage.
Commandant Louis Joseph Lahure has a singular distinction in military history - he defeated a navy on horseback. Occupying Holland in January 1795, the French continental army learned that the mighty Dutch navy had been frozen into the ice around Texel Island. So Lahure and 128 men simply rode up to it and demanded surrender. No shots were fired.
Melvin
Images: 14
Postby Ira » Wed Jul 12, 2006 7:23 am
It says right on the top of that page that it's for interior use.
And come to think of it, do they make ANY kind of mica for exterior use?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Miriam C. » Wed Jul 12, 2006 10:26 am
Woodbutcher wrote:I did not see the interior use on the site. But I did see where it says it moves less then the metal alone does. As for how to deal with the seams, I am building a woody so I wanted to do just the roof with it. I could cover the seam with a wooden rib sealed and screwed down. Any thoughts? Unless the exterior exposure delaminates the metal to their backing I can't see what else could happen to it.
Woodbutcher
this would be real good inside the galley. The problem I would worry about is the sun. UV and heat might permanately warp or damage it.
Now at $20 a sheet how can you go wrong? You might have to replace your roof.
Aunti M
Postby Woodbutcher » Wed Jul 12, 2006 8:59 pm
Ok, you convinced me not to try it for the roof. I have a sheet of Formica with the Bommerang pattern for my galley countertop. Maybe I will look at the Deco stuff for the sides in the Galley. Thanks for the help!
Woodbutcher
Postby halfdome, Danny » Wed Jul 12, 2006 11:01 pm
I've used Kim metal, Wilsonart metal products and Formica metal products for interior applications. The finish is very thin and can be removed with very little effort with sand paper or a file. It's also very thin. Those metals are usually used for decorative applications and are sometimes phenolic backed (looks like sanded p-lam) and would de-laminate with exterior use. I had scraps and chose not to use them on my tear. :relaxing: Danny
halfdome, Danny
*Happy Camper
Images: 252
Users browsing this forum: No registered users and 24 guests
