The structure itself is built. Put the final two panels on the roof. I used 3M panel bond, to fuse the two roof panels. I work in the auto body industry and this stuff is used to glue automobile roofs and truck bed panels on. There have been tests done with this, gluing wood together. You will break the wood, before breaking the bond, so it was perfect for what I wanted. The underlayment, I used on the outside, is some beautiful wood. Too bad, it will be covered in canvas. My only regret, so far, is that I didn’t use it for the interior panels. Live and learn. Just need to make a door, do some final sanding and apply one or two more coats of “the mix”. Then it’s time to canvas.
