Finally underway with our 7X14 V-nose conversion
Re: Finally underway with our 7X14 V-nose conversion
Postby wyldesyde007 » Sun Aug 26, 2018 7:29 pm
Here I have installed the piece which the roof will hang from. The metal angle brackets are attached to each end to counter any torsion on the piece because it's attached edge wise.
I used 4 inch long sill hanger screws to attach it to the wall.
In one of the pics you can see the cut out for the future ducting of the AC into the room when the door is closed.ImageImageImageImage
Sent from my LG-H910 using Tapatalk
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Aug 26, 2018 7:34 pm
Here's the roof in place for dry fitting.
The rocks are on the gate for added weight, I added a few extra turns to the spring to counter the additional weight I was about to add to it and it kept raising up while I was trying to work!ImageImageImage
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Aug 26, 2018 7:36 pm
Roof up checking for parallelism.Image
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Aug 26, 2018 7:38 pm
Now the real fun begins! I brought home the rest of my supplies which I was working on yesterday at work.ImageImage
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Aug 26, 2018 7:41 pm
This is the underside of the roof, I had taken it back off so I could trim a bit off to make it clear the cables better.
What you see me attaching to it is a ramp cleat for the end wall to rest against which I'll show you in a later post.ImageImage
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Aug 26, 2018 7:47 pm
With the roof back in place I started attacking the rear wall which is the next piece of the puzzle.
Here in this close-up you can see how I arranged the connection between the floor and wall, I'm hoping the 1/2" rise will be enough to provide a water break and keep water from intruding in the space.ImageImageImage
wyldesyde007
Images: 131
Postby hankaye » Sun Aug 26, 2018 9:01 pm
wyldesyde007, Howdy;
I'm admiring the thought and work you are puttin' into your back deck. Have you considered
the amount of extra weight you are asking the springs and cables to lift and drop safely?
hank
hankaye
Postby wyldesyde007 » Mon Aug 27, 2018 5:32 am
hankaye wrote:wyldesyde007, Howdy;
hank
I am to a degree Hankaye. When I detached the cabling to rework the pulleys I got to experience the door's weight with out the aid of them and it was already ridiculously heavy. The only things that are going to be additionally attached to it are the rear wall and 1/2" subfloor and I recon I've added 150-200 additional pounds for it to help lift.
wyldesyde007
Images: 131
Postby wyldesyde007 » Mon Aug 27, 2018 5:57 am
And here's the roof raised and locked in position on the rear wall!ImageImageImage
wyldesyde007
Images: 131
Postby wyldesyde007 » Mon Aug 27, 2018 5:59 am
Here's the reason for getting the roof up and the end wall attached first, so that can trace out the cuts on the side panelsImage
wyldesyde007
Images: 131
Postby wyldesyde007 » Mon Aug 27, 2018 6:06 am
I was running out of daylight last night but I couldn't resist cutting out one side panel and fitting it!
In one of the pics you can see the side panel is leaned up beside the door opening, it's my intention that they will be stored here when not in use. The way I have this configuration set up we can erect the roof and end wall and treat it as an awning deck without putting the sides in place hence the use of all exterior materialsImageImageImageImage
wyldesyde007
Images: 131
Postby hankaye » Mon Aug 27, 2018 8:49 am
hank
Nothing to be disagreeing with, I was only asking a question. Apparently you have considered
the extra weight, Good-on-ya!
hank
hankaye
Postby wyldesyde007 » Mon Aug 27, 2018 9:37 am
hank
hank
Lol I didn't think you were
Even considering everything I've considered I would be a fool not to take and seek counsel.
wyldesyde007
Images: 131
Postby McDave » Mon Aug 27, 2018 11:19 am
:applause: :thumbsup: :D
Nice Work
McDave
McDave
Images: 412
Postby wyldesyde007 » Tue Aug 28, 2018 10:34 am
So last night I finished putting down the sub floor
wyldesyde007
Images: 131
