Tongue Box Idea?
Tongue Box Idea?
Postby DWT77 » Thu Aug 30, 2018 2:13 pm
Out of curiosity has anyone used or thought about using a patio HDPE Deck Box on the front of their trailer? Seems like it might be a quick/easy way to add a tongue box.
•Rigid double-wall high density polyethylene (HDPE) construction
•Controlled spring-hinge lid opens greater than 90° – won’t slam shut
•UV-protected panels and lid
•Weather- and water-resistant seal – helps keep interior dry
•Lockable lid
•Can be used as a bench
•130-gallon capacity
•Designed to accept do-it-yourself dividers or shelving
https://www.lowes.com/pd/LIFETIME-PRODU ... ox/3169925
DWT77
Images: 473
Re: Tongue Box Idea?
Postby Sparksalot » Thu Aug 30, 2018 4:49 pm
Similar idea. A Plano box. I made a rack for it from an old bed frame.
153459
153468
Sparksalot
Images: 687
Postby gudmund » Thu Aug 30, 2018 5:53 pm
something to always remember when it come to tongue boxes - there is always a certain point where they can be 'just' too big!! the bigger they are - the more you end up carrying thus the 'more' the tongue weight ends up being!! The other problem a big tongue box can cause problems is when making a 'tight' turn (and/or backing up) a big tongue box can cause damage to the tow vehicle's quarter corners (haven't had this happen to me -BUT- I did get to watch this happen the one time I was waiting for a trailer in front of me to back into a campsite he had choice. Just something to think about :thinking: ..........................take care
gudmund
Images: 39
Postby noseoil » Sun Sep 02, 2018 8:11 am
On the 5X10 flatbed I just built, I used a HF (off the shelf) tool box due to time & convenience. It's a good compromise between a custom build & a factory made piece that works, quick & dirty. It's 12 3/4" high & 33 1/2" wide at the back & 14" front to back, good fit for a standard "A" frame tongue.
Pros: Easy & quick to install, I used self-tapping screws & butyl rubber tape on the frame where it sits
Fits a 50 degree tongue correctly with no modifications
Comes with the factory lock & is ready to set, once it's out of the box
Is fairly well made for the money, steel construction & has a lid lift cylinder from the factory
Cons: Cost $100 (after the coupon discount of 20%)
Weight is 45# empty, this adds a lot when full of stuff, if weight is a concern already....
Had to weather-strip the lid for a better seal, but now it seals well enough
156066
137905
noseoil
Images: 670
Users browsing this forum: Google [Bot] and 1 guest
