HALLMARK 6X12 CONVERSION
Re: HALLMARK 6X12 CONVERSION
Postby hankaye » Sun Sep 16, 2018 6:42 pm
TommyB, Howdy;
Not much of one for Bow-legged trailers ... but ... goin' swimmin' wiff bow-legged wommens :worship: , :twisted: , :thumbsup: , :thumbsup:
:beer: :beer: :beer: :beer:
hank
hankaye
Postby Padilen » Sun Sep 16, 2018 6:42 pm
Dexter, will custom make you an axle if you want !
Id call and ask what the offer and what they think of your current set up.
If your happy with it, &it's safe that's what matters. I just want you safe.
Padilen
Postby hankaye » Sun Sep 16, 2018 6:46 pm
Tommy B, Howdy;
Also, I just remembered (Homer S moment), there should be a tag wrapped around the axle with all of the ID info.
Maker, model, max. weight etc. have that info handy when you contact folks so they can know exactly what it is
you are calling about.
hank
hankaye
Postby Padilen » Sun Sep 16, 2018 6:59 pm
hankaye wrote:Tommy B, Howdy;
hank
Absolutely correct! And they'll send you all the info in an email too.
Padilen
Postby Tommy B » Mon Sep 17, 2018 6:56 am
IM ON IT! Must be safe and done right, absolutely.
Will keep you posted!
Thanks guys. 8)
Tommy B
Postby Tommy B » Mon Sep 17, 2018 9:37 am
Well, here's the story on this. What 95% of you knew already.
Spoke with Dexter manufacturing and then the shop that did the work.
The only bad thing that will happen is premature tire wear. That its. No axle breakage, no difference in handling. Just premature tire wear.
There is no real way to lift the AXLE up. You can only lift the trailer up off the axle by placing the leaf springs on top of the axle with custom blocks and custom U-bolts. Much like 4x4 trucks you see. To get that kind of height would take some BIG blocks and U-bolts.
So again, per advice, I will just run it. My options are to drop the axle down and leave the springs on top with a one inch block or so, It would give you some height. But still put my black tank set up/ at risk. How much is that worth?
Putting this to rest ( the lift ) and I will comment on this after my first run up to Ocala in November. Maybe 450 miles round trip. Maybe 500.
Thanks every body! :D
Tommy B
Postby flboy » Mon Sep 17, 2018 9:49 am
You got it Tommy!
Just see what it does in November. You could always revert to the way I had mine done.
Not as much lift, but enough to reduce any tank bottoming out risks and no camber issues. As you said, you could always add blocks for a few more inches if you just like the looks.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby hankaye » Mon Sep 17, 2018 10:05 am
Tommy B, Howdy;
:thumbsup: , :thumbsup: !!
hank
hankaye
Postby Padilen » Mon Sep 17, 2018 6:33 pm
That's great, gives you peace of mind I'm sure.
Padilen
Postby Tommy B » Sun Sep 30, 2018 2:09 pm
Well only 8 weeks till the first camping trip. :D
Looking at this set up from a differant perspective. The winching bed set up. Thank god I did this when I did this.
Don a few small connections to solder maybe before November but not crucial. TV cable and 12 volt adapter for TV need just a quick fix.
May need to fuse the wrist still but will try to put it off some.
20180929_155745 (Custom).jpg (102.18 KiB) Viewed 4554 times
20180929_132119 (Custom).jpg (85.56 KiB) Viewed 4554 times
20180930_150613 (Custom).jpg (115.95 KiB) Viewed 4554 times
Tommy B
Postby flboy » Sun Sep 30, 2018 3:34 pm
Tommy, We will get all those odds and ends taken care of before the trip. No worries! Looking forward to camping also! How long you in the finger brace?
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Sun Sep 30, 2018 3:50 pm
flboy wrote:Tommy, We will get all those odds and ends taken care of before the trip. No worries! Looking forward to camping also! How long you in the finger brace?
Duuno. Should know more next Friday when I c the surgeon post op. I see a wrist fusion soon though. they say no more pain then. but can I still twist a throttle after? I WILL be camping as planned unless the doc says other wise. I am so restless for fall.
Tommy B
Postby Padilen » Sun Sep 30, 2018 6:13 pm
Tommy, I have a fused right ankle. My injury was in 94, fused in 2013. I dealt to long, probably 10 years to long before getting it fused. In 94/95, Dr and others said don't ride. I still ride, differently but I still enjoy it. The fusion should make the joint pain free. So if it's recommend, don't wait 10+ years in pain.
Padilen
Postby McDave » Sun Sep 30, 2018 9:36 pm
The human body's ability to heal and adapt is truly remarkable. You are doing great Tommy. Hang in there. ... :thumbsup: ...
McDave
McDave
Images: 412
Postby Tommy B » Mon Oct 01, 2018 4:47 pm
Sponsored
[Sponsored]
Dometic-Compatible Flush Ball Seal for 300 / 310 / 320 RV Toilets - Comparable to Part Number 385311658 - By Mission Automotive
by Mission Automotive
Hey my bowl leaks out app 2 qts in 2 min. Just going over things as u know. No smell what so ever but thought I would replace as a matter of PM annually. That should be the part for 22 bucks or so but that seemed a short life span of 2 yrs. Any advice forum?
Don if u r out there I may really need you here and will provide gloves. It may just need cleaned but i will need the wife to do this first but what do you think?
Very little use? :thinking:
20181001_180035 (Custom).jpg (53.61 KiB) Viewed 4531 times
Tommy B
