I don't want a microwave, I don't want air conditioning, I don't want a shower, etc. etc. etc. What we need is a dry place to sleep inside and a fairly well designed galley outside so that cooking, etc. doesn't dirty up the sleeping quarters. I understand that this is an unusual request and the manufacturers/dealers were pretty helpful in focusing us on the few solutions that were at least coming close to our wish list.
Ottsville wrote:Welcome! You've come to a good place for ideas - there's lots of good builds here for a wide variety of needs.
Is building your own trailer or modifying a small cargo trailer in your abilities?
tony.latham wrote:Hello!
I'm failing to see the problem. That's your basic teardrop.
It sounds like you're buying and not building. May I suggest the following quality builders:
https://vistabule.com/
http://tinycamper.com/
https://www.tcteardrops.com/
I've looked closely at those brands and they are all well built.
There is a user Cosmo, who has a Vistabule and tows it with a Subaru. He also likes cooking.parandyb wrote:tony.latham wrote:Hello!
I'd say you fail to see the problem because you solved it long ago.Thanks very much. These are much closer to what I am looking for. I'm a cook so I love the more elaborate storage in the galley of the Vistabule, but it may be a bit heavy and larger than we need. We need to either keep the weight to about 1000 pounds or put electric brakes on because it will likely be towed behind one of the new Subaru Forrester's coming out next year that only have a 1500 towing capacity. But this is a great start and much better than I was finding searching the net on my own. The closest I found in Hershey was Nucamp and there you started with all the goodies and had to subtract to get here. Thanks again.
