soapcreek wrote:Progress has been at a standstill while I’m acquiring the needed paint products. I picked up some por-15 for the frame and u-pol raptor liner has been on order for a few weeks. After Amazon bumped my delivery for third time I found another source and it should be here Friday.
Question for the raptor liner users, are you laying down a layer of penetrating epoxy before spraying? I know you can spray directly but was curious if the epoxy was worth piece of mind.
DWT77 wrote:soapcreek wrote:Progress has been at a standstill while I’m acquiring the needed paint products. I picked up some por-15 for the frame and u-pol raptor liner has been on order for a few weeks. After Amazon bumped my delivery for third time I found another source and it should be here Friday.
I have been using a 3.25oz tight weave and raka epoxy before I spray the raptor bed liner. My thought if it were to crack, branch scrapes a piece off, ect.. that would give me added protection.
When I contacted U-POl they recommended at minimum to put a water sealer like Thompson's before spraying the bed liner. They also have an adhesion promoter I have been prepping it with before I spray the bed liner.
tony.latham wrote:they recommended at minimum to put a water sealer like Thompson's before spraying the bed liner
That stuff is paraffin dissolved in a solvent. I can't imagine it as a base coat for a bed liner material.
Here's the data sheet:
http://archpdfs.lps.org/Chemicals/Thompsons-Water-Seal.pdf
Thoughts?
DaddyJeep wrote:You are going to top coat the POR 15, right? It will turn grey and chalky without a top coat.
