fishboat wrote:
...I just looked up the suggested wire gauge for a 1% voltage drop over a 20 foot, 12V umbilical..cough..I didn't realize 12V voltage drop was so bad..yikes. The calculator suggested 0 GA wiring(8 amps, 20 feet, 12Vdc, 1% drop), 4 GA for a 3% drop..
Are you sure you typed that in correctly to your online calculator?
When I check a couple of my favorites and enter 12 VDC, 20 ft run, 1% voltage drop , 8 amps out, I see at most 4 AWG, and that uses the total round trip length of 40 ft.
Zero gauge seems awfully big for 8 amps running 20 feet, and 1% seems rather small for a max voltage drop, 2% seem fully acceptable to me (11.76 VDC)
No harm in buying extra copper as long as you don't mind fighting with a stiff and heavy umbilical.
Ottsville wrote:Sure it can be done and previous posts all give some good points.
Here's a couple of random thoughts though. Make sure your batteries are separated from your automobile battery so that any draw doesn't kill your automobile battery as well.
I prefer to have batteries on the trailer for ease - one less thing to have to load every time you decide to head out plus you have power to trailer when the truck isn't there.
If you're worried about tongue weight on the truck then having battery, charger, and fridge in the truck is actually worse than having them on the trailer because the weight is shared by the tongue and the axle if they're forward of the axle versus all on the rear axle of the truck plus the tongue weight. If your tongue weight concerns relate to towability then you possibly could move your axle slightly forward or rearrange your loading to compensate for more weight in the front.
GTS225 wrote:I'd have to advise you to drop the dual 6V battery idea now. If you're set on dual batts, run two 12 volt batteries. Dual 12's will not really weigh much more than dual 6's, and give you twice the amperage availability, for a longer run time.
As for cabling, if I'm not mistaken, you can still get a good sized pair of jumper cables for a decent price. That will give you high-amperage cable for less than hitting up your local Home Depot.
OK, maybe I'm not following your thought processes. You're planning for a 1% voltage drop over 20', but that is also dependent on amperage draw through that same cable. As the draw goes up, so does the voltage drop, as the wire size is the "choke point", if you will.
Just how much amperage do you anticipate pulling from the tow vehicle?
Remember, your starter motor in your tow vehicle pulls 130-200 amps, and those cables really aren't that big.
Roger
KTM_Guy wrote:What is your tongue weight now?
What’s the TV?
Do you need battery power for weeks on end or just to last a weekend trip?
Do you need the back of the trailer to be clear to hall stuff?
Water is another high weight gain. Do you need to carry it and how much? Where will you carry that?
Why? I very commonly use 00 or even thicker when needed.fishboat wrote:I just looked up the suggested wire gauge for a 1% voltage drop over a 20 foot, 12V umbilical..cough..I didn't realize 12V voltage drop was so bad..yikes. The calculator suggested 0 GA wiring(8 amps, 20 feet, 12Vdc, 1% drop), 4 GA for a 3% drop..that's not going to happen.
