Chesapeake CLC
Chesapeake CLC
Postby greenchicken » Wed Nov 14, 2018 1:22 pm
I started another post about designs that led to posting about this TD Kit.
I was exciting about building this from scratch to my own specifications but I can't deny the appeal of this kit.
Right now the main draw back is the cost. But as I prepare my materials list I am wondering if it really is that expensive.
Opinions? Is $2,200 significantly more then I would spend on all the material?
And...
Other then the trailer itself what else do I need to buy to complete this kit?
greenchicken
Re: Chesapeake CLC
Postby edgeau » Thu Nov 15, 2018 2:45 am
I am in a different country so our costs are not directly compatible but I did keep a materials list. It adds up pretty quickly and I used recycled materials where I could.http://cloud.tapatalk.com/s/5bed2c8dbd646/teardrop_costs%20%281%29.pdf
Sent from my Pixel using Tapatalk
edgeau
Re: Chesapeake CLC
Postby greygoos » Thu Nov 15, 2018 7:25 am
I know at least one build of the CLC was documented on this forum. Use the search bar and you will find it
greygoos
Re: Chesapeake CLC
Postby friz » Thu Nov 15, 2018 7:48 am
I have about 4k in mine total with a Northern tool aluminum trailer. I bought the kit. The materials are first rate and having all the pieces precision cut is priceless. I did do my own interior. ImageImage
Sent from my SM-G930V using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Re: Chesapeake CLC
Postby tony.latham » Thu Nov 15, 2018 9:40 am
I'll betcha I'll spend close to $4500 on build #4. Maybe a bit more.
:thinking:
Re: Chesapeake CLC
Postby gudmund » Thu Nov 15, 2018 10:01 am
friz - S W E E T - I am impressed!! you did a nice job!!! :thumbsup: :applause:
(note: something to remember about money - here today, gone yesterday)
gudmund
Images: 39
Re: Chesapeake CLC
Postby koolkingkev » Fri Nov 30, 2018 3:14 pm
That is so beautiful and thanks for not giving in to the neg.
Was the trailer the NT 5x8?
What rim wheels did you choose?
The hitch box isn't clc's what is it?
koolkingkev
Re: Chesapeake CLC
Postby Andrew Herrick » Fri Nov 30, 2018 4:43 pm
Costwise, my understanding is that a CLC will cost you about the same a conventional homebuilt teardrop, but the homebuilt 'drop will have more insulation, electrical features, space, windows, etc. So on a feature-per-feature basis, the CLC will certainly cost more. However, it looks friggin' awesome, and it does 90% of the design work for you.
A few of my builds:
Andrew Herrick
Images: 15
Re: Chesapeake CLC
Postby friz » Sun Dec 02, 2018 8:01 am
koolkingkev wrote:That is so beautiful and thanks for not giving in to the neg.
Yes, the trailer is the NT 5x8. I hacked a bit off the back to get my camper to fit. The tongue box is NT also. The wheels came from etrailer. They are the same size as stock with radial tires. The NT tires wore out in just a few thousand miles. The radials are doing much better.
The "Sin Bin"
150133
friz
Images: 6
Users browsing this forum: Google [Bot] and 1 guest
