As most of you know, conventional insulation materials have an R-value of R-3 to R-8 per inch (in truth, marketed R-Value is a gross oversimplification, since the R-value of material fluctuates based on age, dominant heat transfer mode, etc). Anyhow, back to the topic. Vacuum insulated panels have an R-value of 20-40 per inch!
They work similarly to a vacuum thermos. Once you factor in edge effects and other compromises, it's more accurate to estimate R-15 to R-25 per inch for a whole-wall assembly.
However, cost is substantial. While a 4x8 1-inch thick of insulation foam (R-4.2 to R-6.7) can be had for $11 to $30, a 4x8 panel (or equivalent) VIP might cost $400+ (gulp). They also suffer from the obvious flaw that if punctured, they will lose a great deal of their effectiveness.
I don't really have a point to this post
