GeekFisher wrote:KTM_Guy wrote:My cross members are a mix of 2X2 X1/8 angle and 1X2 12 gage tube. That space in the middle is where future water tank will be. Abour 30 gallons. Centered over the axle.
Size your roof spars for your insulation. The roof rack typically mount to the side wall. Make sure you have solid backing to have something to screw into. A stud should be under the backing down to the floor. Did you say how you are building your walls? Stick built or skeleton method ?
If you are wanting to be 1,000-1,2000 pounds finished weight for a trailer that size you need to thinking “ultralight” ALL THE TIME. Instead of using 3/4” wood ask yourself can I use 1/2” or 1/4”. Weight adds up fast.
Todd
I expect to use 1-1/2 thick Isoclad stuff (foam with air barrier) for everything except maybe the floor so 2x2 made sense when I designed. I don't know the difference between skeleton and stick build. I thought about going kinda house-like, studs every 16in centers (when possible...) with studs where the partition wall will be since I plan on insulating this wall but not the galley walls as it doesnt need it. Roof spars would be cantilevered on the side walls if that makes sense (it might not, in the end...)
I don't want to use anything thicker than 1/4" for plywoods. Here is where I am so far:
- 1/4 outside and 1/8 inside for sidewalls.
I used 1/4 both inside and out. 1/8" isn't much if you have to attach things like hooks to the wall. Try to pre think stuff like that and add backer.- 1/8 at the very bottom and 1/4 on inside floor
I did 1/8" top and bottom. Nest time I will do 1/4" bottom and still 1/8" top side. I'm thinking something on the road or trail could damage the 1/8 more so 1/4". You don't walk on the floor and the mattress spreads and distributes the weight.- 1/8 roof and ceiling
I did the same.
KTM_Guy wrote:
300w 12v heater is 25 amps, 100AH battery taken to 50% gives you 2 hours of run time, as long as you don't use any other power. It just doesn't make sense to make heat out of 12v battery power. Look into a Little Buddy heater or better yet one of the Chinese diesel heaters that has combustion air.
Todd
Andrew Herrick wrote:Your proposed use of an exterior WRB (Tyvek) is dependent on a dozen other factors. It's not a yes-or-no question. There are very few situations where it would hurt, but quite a few where it would do no good. What's more important than a continuous WRB is that you flash all penetrations and openings (hatches, windows, fans, doors, etc.) so that any intrusive water is redirected to the exposed interior wall and NOT into the wall cavity. In a camper, the humid air is usually the interior air, so you might be better off installing Tyvek on the INTERIOR-side to prevent warm, humid interior from migrating into the wall cavity, hitting the cold exterior, and condensing into bulk water INSIDE your wall. A WRB on the exterior isn't normally harmful, but since camper exteriors (unlike a house) aren't designed to dry from the outside, the uses of a continuous exterior WRB are limited.
GeekFisher wrote:I also found an epoxy supplier in the area so I'll be able to glass floor, side and roof. I was also wondering which type of asphalt coating should I use for the undercarriage ?
Fibrous roof coating or non-fibrous roof coating or non-fibrous foundation coating ? I feel like fibrous would hardened the wood a little bit and since I'm using thin stuff this is appealing. Any thought about that ?
Also, after reading too much stuff about it, I decided to get rid of both the vapor barrier and the WRB (Tyvek/Typar kind of white canvas)
I feel that these are not needed with rigid foam with epoxied walls. I will tape the foams to the 2x2 studs though. Do I need foil tape or duct tape will just do fine ?
Thanks all for your very useful replies to this point and your indulgence with a newbie like I am ! Very appreciated and can't wait to get back to work
Andrew Herrick wrote:Fibrous roof coatings are stronger, but less elastic. Non-fibered roof coatings are more elastic, but less strong. Pick your poison .... In actuality, an elastomeric roof coating is your best bet. They are 2-3x more expensive, though. If you go with a cheaper asphalt emulsion roof coating, you might wind up with hairline cracks in your first coat after a year or two, but it's not hard to touch up with a second coat.
Taping the foams to the 2x2 studs is an excellent idea. Foil or duct tape, well, isn't lol. Foam, especially low-density insulation foam, shrinks. And while lots of tapes have decent initial tack to the foam, most won't hold more than 24-48 hours, ESPECIALLY after exposed to thermal and/or humidity cycling. Thankfully, there are tapes specifically designed to bond to rigid foam insulation. 3M 8087 and 3M 8067 are my favorites.
GeekFisher wrote:Thanks for your reply !
Insulation tape readily avail is http://www.canac.ca/en/product/building ... ite=001002 it is made for insulation. The insulation I'll be using is blue or pink foam (depending on which brand I choose)
Would elastomeric roof coating give any strenght ? Because it's almost $=$ with Epoxy so might go epoxy all the way around ? Also, if I plan on skinning in aluminum, do I need to seal exterior walls ? I planned on sealing the roof with Epoxy anyway but was unsure about exterior sidewalls.
Thanks,
