flboy wrote:This is what I have for the battery compartment vent. The cable pass in the floor through serves as an fresh air inlet and will allow the heavier sulphuric gas to drop out in the event of overcharging. I am going to use 2 of the louvered vents on the side at the top of the compartment above the batteries since the compartment is long. Lastly, I need to put some rubber weather seal on the dinette seat lid and the lid in the bottom of the closet. They may not be 100% airtight, but with the vents... I do not think any gasses will have the chance to accumulate.
Now that I do not have SLA batteries.. I think this is needed for safety.
JRAnt74 wrote:Thanks for the vent info, will look into a couple of them for my battery box. I'm thinking of doing the 2 6v golf cart batteries myself. Not an imediate need but I would like to get the box built now. If it isn't too much to ask what are the dimensions of one of those batteries? Trying to build out my new cargo trailer as a mobile workshop. Thanks again in advance kind sir.
McDave wrote:You could probably get a pretty penny for those exides still. Nice upgrades this weekend, and that pad sure is nice to park and work on. Say Don, is your old buddy Benz still around? Haven't seen any pics lately with the tailwagger in there. I hope so, but I know they get old. Might be a good thing to have a friend like that when you travel, and one to keep an eye on mama too.
McDave
featherliteCT1 wrote:I am no expert and am easily confused …but does it make sense that the chart says at 50 degrees at 50% charge, the battery would read 11.596 volts? And at 50 degrees at 90% charge the volts would read 12.116 volts?
I have read that we should subtract 0.024 volts for every ten degrees F, if the temperature is below 80 degrees F ... does that sound right?
The chart does not agree with the data at http://all-about-lead-acid-batteries.ca ... orrection/
I wonder … which chart is correct?
Also, a while back, I bought three different hydrometers from three different manufactures that looked similar to the one you posted ... but all three gave wildly different readings. I never knew which one was correct.
Any thoughts?
flboy wrote: I paid $199 to flip both axles and it would be about half that. Tommy had his single axle flipped and it was about half. The axles are not welded to anything... the "perches" where the axle engages the leaf springs is welded on and they welded new perches on the opposite side and leave the originals in place. The axles do not really "flip in the this case... they are just mounting them under the leaf spring instead of on top. I hope this helps.
