I'm just talking a similar frame layout, which is bog standard.Andrew Herrick wrote:But a similar design rated to carry 15,000 lb? There isn't much like that on the market. So there's less to borrow off of.
And sadly, you can't "scale" a trailer design. The loads don't increase proportionally. You're really talking an entirely new trailer.
The fact that it's aluminum adds a layer of complexity few hobbyists are familiar with. For instance, welding 6061-T6 aluminum anneals the metal in the HAZ from a T6 to a T0 temper, meaning it loses almost 80% of its yield strength. And the fatigue strength of structural aluminum is around 11 ksi ...
I'm not saying you can't build a bolted aluminum trailer rated for 15,000 lbs.
may as well add 10% for expert help!
John61CT wrote:I'm just talking a similar frame layout, which is bog standard.Andrew Herrick wrote:But a similar design rated to carry 15,000 lb? There isn't much like that on the market. So there's less to borrow off of.
Say the base platform costs $7000 in materials.
Do you really think a qualified US-based engineer would be willing to spec those materials and rough-sketch the bolt / reinforcing details for $700? Maybe pay for one week of E&O insurance? ;-)
If so, you're right, well worth it.
Of course maybe a sharp overseas engineering grad student online would do the same for $100, without any liability exposure.
The key I guess is choosing a state to register and insure.
Andrew Herrick wrote:Just to call attention to something the OP is doing correctly:
He appears to be sizing the bolt such that nothing is "short-bolted" - that is, there's at least one full bolt thread extending past the nut. That's extremely important for fatigue resistance. "Short-bolting" increases the chance that a bolt or nut will break due to low-force cycling over time. So, +1!
Yes, a gross-dimensioned SketchUp model, just looking for specs / sources on buying the materials, and details on the bolt / plate joins, or where welding would make more sense.Andrew Herrick wrote:I'm not a PE myself, so I can't guarantee anything ... but I've heard of similar prices for similar servicesA PE can do what a layman either can't do or would take 20x longer to do. This is assuming you've prepared at least a meaty skeleton of the plans for review. If the PE has to generate the product from scratch, I'm sure that's more expensive ...
redbicycle wrote:That's going to come out great. You have a lot of hours into this build already.
