bdosborn wrote:I don't understand how it helps. You might be able to overcome the internal resistance of each battery and charge it to a bit higher level but not much since the batteries are still connected to each other and as such must all be at the same voltage. Then it seems to me that the batteries are going to discharge at different rates (per internal resistance) and equalize to the same voltage level across the array as soon as you apply a load. The unequal discharge rate would be compounded by any difference in resistance across the battery conductors due to different lengths. In short, the batteries are going to quickly seek their own charge level during use.
So how is it supposed to benefit your battery bank? Not trying to troll, I'm always on the look out for a new battery gadget.![]()
I have no idea.. that is why I am asking.. Anyone? I guess I do know at least this much.. I am not going to spend money on it.
