I am needing help from all you framing Guru's out there!
My next design is going to be a small bread loaf, micro-sized Shasta Compact, or a Midget/Widget design. I am needing ideas for a very compact and super low (about 8" Clearance) frame.
Approx. Size of this will be:
Total length 8' ft. (Excluding the tongue)
Total width 6'-7' ft.
Total height 6',6"-6' 8" ft.
I am also thinking it will be a foamie/hybrid skinned with 1/4 wood on the outside and inside as well, so all fingers crossed i should be in 900-1000 lbs. total weight (hopefully 700-800 lbs).
I will be welding this myself, so i can make a drop frame or something along those lines if need be. Any help on this would be great!
