profile comment...last chance
Re: profile comment...last chance
Postby edgeau » Thu Feb 07, 2019 3:27 pm
Atomic77 wrote:
edgeau wrote:
Atomic77 wrote:
edgeau wrote:I got this door shape to seal.
Just curious... What are you using to seal the door? Because from the pic's I can't see
Sent from my SM-N950U using Tapatalk
The dark outline you see in the first picture...
Ok, I see. So how does it do at 60mph in a rainstorm?
No problem.
Sent from my Pixel using Tapatalk
edgeau
Postby Atomic77 » Thu Feb 07, 2019 3:54 pm
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby greenchicken » Fri Feb 08, 2019 4:04 pm
Thanks for all the feed back.
I have a plan for the seal. I will share shortly.
As for the Hinges.... Those are just temp. My friend and I forged hinges from car leaf springs. They will easily handle the weight of the door.
I was most pleased to add some forging to this project, it is one of my new passions.
Yes.... your eye ball is most accurate: it is approx 40" in diameter. My son was insistent on a Round Hobbit door. But I will re-evaluate the getting in and out.
Close.... It will be 4,5 feet high and 9 feet long. I plan to have a very small pantry.
Screen Shot 2019-02-08 at 1.38.00 PM.png (814.07 KiB) Viewed 637 times
Screen Shot 2019-02-08 at 1.38.13 PM.png (744.69 KiB) Viewed 637 times
greenchicken
Postby Ron Dickey » Fri Feb 08, 2019 11:17 pm
i looked around the net all have longer hinges and many had a support shaft or pin joining both hinges. All them had a extra thinkness around the door to hold it when closed.
You could have a round door going over a rounded square opening
many had additional locks to keep it closed. Luck up round boat door and go to images.
Rest of design looks good.
173882......173887
Ron Dickey
Images: 787
Postby greenchicken » Mon Feb 11, 2019 12:16 pm
The deed is done. I am now fully committed!!
Screen Shot 2019-02-11 at 9.47.28 AM.jpg (245.84 KiB) Viewed 588 times
greenchicken
Postby tony.latham » Mon Feb 11, 2019 1:11 pm
Well, it surely looks great! :thumbsup:
