Hinge Advise
Hinge Advise
Postby greenchicken » Mon Feb 11, 2019 12:53 pm
Need to order my hurricane hinge for the pantry.
I have no idea which style I need.
Hinge 1
Hinge 2:
Hinge 3
greenchicken
Re: Hinge Advise
Postby Modstock » Mon Feb 11, 2019 1:06 pm
It all depends on how your hatch sits (flush or raised) with the rest of the body.
2 and 3 are basically the same. 3 looks like it has a spacer.
Sent from my H1611 using Tapatalk
Modstock
Re: Hinge Advise
Postby tony.latham » Mon Feb 11, 2019 1:08 pm
It depends on how you are constructing your hatch. I build a Fredrick's style that is the same elevation as the roof.
So I use the second one in your photo lineup. :thinking:
Re: Hinge Advise
Postby FM82 » Mon Feb 11, 2019 1:15 pm
As far as the second two hurricane hinges, it depends on your hatch design. Check out their images in the link below. If I'm not mistaken, the hinge in your first image is just a different style joint, and designed for a 1/4 roof to hatch offset.
https://www.teardroptrailerparts.com/hu ... t-bar.html
Sent from my XT1650 using Tapatalk
I have no idea what I'm doing.
FM82
Re: Hinge Advise
Postby FM82 » Mon Feb 11, 2019 1:16 pm
You guys beat me to it haha. The more info the better, I suppose.
FM82
Re: Hinge Advise
Postby greenchicken » Mon Feb 11, 2019 2:15 pm
Well then..... what hatch design would you recommend as the easiest vs best.
I was planning on it being flush.
BTW: The prices are about $70 on the Tear Drop Trailer Parts website. Is that a good price?
greenchicken
Re: Hinge Advise
Postby tony.latham » Mon Feb 11, 2019 2:35 pm
That's a tough question. I've only built one way. Are you using sandwiched walls?
Here's my next hatch seal detail:
And the frame:
:frightened:
T
Re: Hinge Advise
Postby edgeau » Mon Feb 11, 2019 6:37 pm
Tony's hatch seal diagram is great. That method keeps water out really well.
Sent from my Pixel using Tapatalk
edgeau
Re: Hinge Advise
Postby KTM_Guy » Mon Feb 11, 2019 10:37 pm
I went with a 3" aluminums piano hinge and covered it with EPDM rubber roofing.
In this photo I haven't finished trimming the rubber yet.
The hurricane hinges don't seem very heavy duty for me running mile after mile of washed out dirt roads. And I am more after dust proof which I'm not sure of with a hurricane hinge.
Todd
KTM_Guy
Images: 193
Re: Hinge Advise
Postby tony.latham » Tue Feb 12, 2019 10:09 am
I don't get dust in my galley and we do many-many miles on dusty roads.
Perhaps it is just too high to be exposed?
Re: Hinge Advise - Hurricane hinge with a rain gutter
Postby Esteban » Wed Feb 13, 2019 12:34 am
hurricane hinge with a rain gutter: https://goo.gl/images/jAov5u
:) There is another Hurricane Hinge to consider. A Hurricane Hinge with a built-in rain gutter is sold by Overland Triailer https://www.overlandtrailer.com/product ... tch-hinge/ and by TCTeardrops (video demonstration of the hurricane hinge with a built-in rain gutter). You can call one of the phone numbers shown at www.tcteardrops.com to order one cut to the length you need.
:thumbsup: Tip: Use a hurricane hinge that is about 3/4" to 1" longer, on each side, than your roof/hatch to get the best water protection and runoff.
Steve - SLO, CA
Esteban
Images: 15
