The total volume would affected greatly in that case. Of course it would depend on how many of the 3" vents you installed, but, you would need to install enough 3" vents to equal the same volume opening as the fan-tastic vent for the air flow volume to be the same. Without that, the velocity would increase, but the volume would be reduced.les45 wrote:On my current standy project I will have a Fantastic fan in the center of the roof but my windows will be fixed. The windows in the door can be opened for airflow but I would like to get some airflow over the front and rear ends to cover the bed area and the dinette area. I am contemplating some sort of existing trailer type vents but most of them are limited in size (about 3" diameter). My question is how is airflow affected by the reduced diameters? I know velocity would increase but how would the total volume be affected?
FM82 wrote:... you would need to install enough 3" vents to equal the same volume opening as the fan-tastic vent for the air flow volume to be the same. Without that, the velocity would increase ....
