featherliteCT1 wrote:
Thanks for the info!
Thanks Brotherman. It's our ongoing saga.KCStudly wrote:Very well written and well worth the read. You always manage to convey the love and attention to detail that continues to go into you project so well, and in an entertaining way. I'm riveted!
OP827 wrote:I see you guys are really serious about sticking to the mid-century theme. That is a great fabric pick and thanks for sharing the story
pchast wrote:Nice find. I like that pattern.
Atomic77 wrote:Need me to head that way and give you a hand?!
KCStudly wrote:Atomic77 wrote:Need me to head that way and give you a hand?!
That would be awesome (once the weather warms up)! We'd probably have the bodywork done in short order with a master of the art like you manning the spray guns and air sanders. I have little to no experience there; the only time I tried to use a DA on TPCE I made more work for myself than I saved.![]()
Based on your input (and that of others), I am more seriously considering switching to a high build primer, stick a couple of box fans in the windows with furnace filters, cover a few more things in plastic and have at it.
Thank, my Brotherman, for the constant support and encouragement. It is indeed a brother/sister-hood!
Any danger of the fuel pump freezing up under the coach?OP827 wrote:I would consider location outside, so you do not have diesel smell inside camper. The tank must have a small vent hole in any case. Also the fuel pump is making clicking noise, so locating it outside to reduce noise when you sleep is not a bad idea..
Atomic77 wrote:Any danger of the fuel pump freezing up under the coach?OP827 wrote:.
Sent from my SM-N950U using Tapatalk
