Here are a few recent pics of my 5 100W panels after I painted the roof with Henry's Roof paint.
Three cross members and only 6 screws into the roof on outer edges into steel frame to minimize impact and opportunity for leaks. Panels double up on the middle crossmember.
I also mounted them front and back like I did with the brackets dropped down to keep profile low and close to roof. There is little to no air getting underneath to create lift and stress on the highway. It has been a few years now and no signs of any movement or stress.
A closer look how I mounted with brackets I made from 1 in aluminum angle stock as I was installing. Just cut 4 inch pieces and used them front and back to set on crossmember. It allows the doubling up on center crossmember. I did push them together before I screwed them down. I was just sizing it all up in this pic.
