After the trailer was built we filled in all the screw holes with bondo then sanded the wood and sprayed the bare wood with Raptor liner.
I’m seeing bare wood and having seam gaps.
lacofdfireman wrote:So I built a custom off road style Teardrop trailer and decided for exterior to use 1/4” Baltic Birch Plywood. After the trailer was built we filled in all the screw holes with bondo then sanded the wood and sprayed the bare wood with Raptor liner. It when on think and dried super hard. I thought with as much as we put on this was going to be bullet proof. But seems with Heat, cold and rain the wood is contracting and shrinking and causing the Raptor liner to crack and now I’m seeing bare wood and having seam gaps....
tony.latham wrote:Ouch. (and by the way, I can't see the problem in the photos)After the trailer was built we filled in all the screw holes with bondo then sanded the wood and sprayed the bare wood with Raptor liner.
Was the wood sealed in any fashion before the bedliner?I’m seeing bare wood and having seam gaps.
Wood seams? At the front angles?
I'm trying to understand what's going on here.
I'm with Woodbutcher. You could pull everything off it and sheath with aluminum. A brutal suggestion.
T
pchast wrote:How did you seal the inside against moisture?
Could that have been a factor too?
