tony.latham wrote:Andrew:
I'm busted.
But there's another 30% of my posts that abhor the use of OSB in campers.
With as much effort that goes into these projects, I hate seeing people cut a few corners to save a handful of bucks.
Agreed.
I'm busted.
Andrew Herrick wrote: Russian - not Chinese - Baltic Birch is made with an exterior glue and less than a handful of voids per sheet. It's the standard for teardrop construction, and many Baltic Birch shells have decades of use under their belt. It's great stuff.
Unless you're lucky enough to live in an area where it's easy to special-order plywood from big manufacturers like Roseburg and Columbia, the choices are often slim. Anyhow, back on track .... interior-grade panels work - until they don't. You don't get the forgiveness inherent in an exterior-grade plywood.
Since you plan to paint the exterior, I'd go with Baltic Birch or ACX plywood. You don't want the telegraphing of a B- or C-grade panel, and unless you like spending money, I can't imagine marine plywood will improve the build. Take your savings and splurge on a higher quality paint
Tom&Shelly wrote:twisted lines wrote:Thank's to you to all.
First Complete top layer will be .125and then wing it.
Could you just put another 1/8" layer over that one?
I'm gonna have to look for something like that, double them up you know.Sparksalot wrote:I recently built a stitch and glue kayak using 3mm plywood. It's marine grade Okume, so be prepared for sticker shock. On the other hand, how much are you really using?
swoody126 wrote:PS, @ just over 3 hours northeast of you is Clark's Hardwood Lumber Co. in downtown Houston
https://www.clarkshardwood.com
they are 6+ hours south of me
they offer the best prices in Texas/the southwest(cheapest prices in Ohio for large quantities due to shipping costs) on marine lumber n plywood
i get my 6mm Aquatek miranti from them for boat building when i only need a few sheets
they carry fir, okoume, Hydrotek & Aquatek marine grade plywoods in thicknesses from 3mm ^^^
https://www.clarkshardwood.com/?s=aquatek
as mentioned above be ready for sticker shock
IMHO the 3mm Okoume might offer the better bending qualities
sw
swoody126 wrote:Preston, 1-18-18 is my last note to me about their pricing
Aquatek 6mm - $43
Hydeotek 6mm - $55
hydrotek 12mm - $100
sw
