Also, anyone on here wire up their camper to their alternator for charging down the road?
It will run for two days before the battery stops.
troubleScottie wrote:Actually, the other poster (Cosmo) suggested running 12VDC from the tow vehicle (TV) to the trailer, not using the inverter.
One could run your battery charger. However there are lots of power loses go from DC to AC back to DC.
For a direct 12VDC connection, the general plan is an appropriate fuse, an always open solenoid (switched on to allow charging of trailer battery), an long run of wire to end of TV for the plus wire; just a long run of wire for the common; then a connection (Anderson connector pairs?), then two wires on/over the trailer to the battery. Think big audio amplifier in trunk. 6AWG sounds good.
The major draw back is the alternator is not quite the same as a multi-stage charger. So the battery may not completely charge. Of course depends on length of charge time, state of battery, etc.
Some solar MPPT allow connection from TV, so you can get a staged charge. However, you are then limited by the amperage of the MPPT unit. Some are small.
Burro wrote:Need some guidance about a solar setup.
I only run a fridge off my deep cycle battery and would like to extend my use some.
I have a small fridge that pulls 1.4 amps when its running and 6.3 amps when starting up. I run it off a group 27 battery and an inverter. It will run for two days before the battery stops. I’d like to extend the duration of how much time I can stay off shore power. So, I was going to add a 100 watt solar panel.
It looks like I might be able to put about 5amp hours an hour back into the battery (given optimal conditions). Does this sound about right with a 100 watt panel?
Some side questions. Has anyone glued a flexible solar panel to their teardrop? Just curious how this would work? If I could avoid putting holes in my aluminum that would be my preference.
Also, anyone on here wire up their camper to their alternator for charging down the road? I was thinking if using some 6 gauge old jumper cables to run a large gauge line from the alternator to the trailer battery with a relay to turn off when the truck is not running. The 7 pin 12volt line is worthless for charging the battery. I could drive across the country and never charge the battery.
Thanks for any advice or links to previous posts!
Just wondering do the guys charging off there tow units alternator do you use a Dc - Dc charger...
Users browsing this forum: Google [Bot] and 8 guests
