Any regreats going 60'' over a 48'' HF. frame
Postby saywhatthat » Thu Feb 28, 2019 1:16 am
Any regreat going 60'' over a 48'' HF. frame. Thinking going with a HF frame .I just cant find the time to do my build. It take not a thing to go 60 in wide there no waste . The pod should not be over 200 lb./ 91 KG. Dose any think you had to box the wheels made it a bad ideal ? It will go from snow to 75 + in the next 3 weeks so would like to get one more done .As I have over 500 feet of railing taking room
N’importe quel régression allant 60'' sur un cadre de 48'' HF. . Pensez à aller avec un cadre HF . Je ne peux pas trouver le temps de faire ma construction. Il ne faut rien pour faire 60 po de large, il n’y a pas de déchets. La gousse ne doit pas dépasser 91 KG. Pensez-vous que vous avez dû boxer les roues en fait un mauvais idéal ? Il passera de la neige à plus de 75 au cours des trois prochaines semaines. Comme j’ai plus de 500 pieds de garde-corps
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Re: Any regreats going 60'' over a 48'' HF. frame
Postby Bigwoods » Fri Mar 01, 2019 7:38 am
It was easy to widen the HF trailer to 60" so you didn't have to build over the wheels. Several did that a few years ago including mine.. Has worked great.
Greg in Northern Minnesota
Bigwoods
Images: 104
Postby EZ » Fri Mar 01, 2019 11:55 am
Bulding a floor frame using 2 X 3 lumber on edge will raise the floor enough over the wheels that building around them is not needed. It is easy to do and going 66" or more wide is not a problem. I did that on my first build and had no issues; worked well.
Ed
EZ
Images: 72
Postby saywhatthat » Fri Mar 01, 2019 1:25 pm
IS there any chamfer on the axle ?
Good to know that I need to rise the floor up 3'' .Now more to think about :?
saywhatthat
Images: 135
Postby EZ » Fri Mar 01, 2019 3:48 pm
That is just what I did (as have others on the forum) and it worked well. There is enough clearance over the tires when using this method.
EZ
Images: 72
Postby saywhatthat » Sat Mar 02, 2019 1:13 pm
THANK you for the pictures. I am using a glassfoam floor try to stay away from wood .To hard to work with. As there is only 3'' to deal with may make new axle mounting pads and reinstall axle under spring
saywhatthat
Images: 135
Postby Woodbutcher » Sat Mar 02, 2019 1:39 pm
This is how I did mine. Some of these picture show the floor upside down. There is a drop floor so I could sort of stand up. The trailer cabin sides were 60" tall.
This picture shows the profile pattern I used.
Woodbutcher
Postby saywhatthat » Sat Mar 02, 2019 4:18 pm
Rub it in .I find if I cut wood will soon be a wood pick. That why with glassfoam can't mess up cut to short 10 times bond more on. Wish yourcloser would like to pull tolling off the floor .
saywhatthat
Images: 135
Postby Muran123 » Sun Mar 03, 2019 3:52 pm
Hello how did you seal the bottom ?
Thanks Steve
Muran123
