Piano Hinge
Piano Hinge
Postby BillD » Wed Mar 27, 2019 4:27 am
Hi.I placed rubber under P hinge ,it pinched and failed .Has anyone had success with placing rubber above hinge ..?
Thanks Bill
BillD
Re: Piano Hinge
Postby BillD » Wed Mar 27, 2019 6:15 am
BillD
Re: Piano Hinge
Postby Tomterrific » Wed Mar 27, 2019 8:52 am
My hurricane hinge leaked the first time i opened thw hatch. Dew on the hatch came through by capillary action. At that instant I knew I should have used a stronger, easier to install and much less expensive piano hinge. Congrats to you for making a good choice.
My leaky hinge was repaired by using rubber over the top. A friend gave me a 1 foot wide roll of thin tough rubber for roofing. I split the width into 6" strips. The edges were secured by aluminum carpet/flooring transitions screwed through on the edges. I cut the rubber long so it will hang over the edge of the roof/hatch. Install the rubber flat to the hinge as it will bow up when the hatch is opened.
Many folks have done the same rubber over hinge with good results.
Tt
Tomterrific
Re: Piano Hinge
Postby KTM_Guy » Wed Mar 27, 2019 9:18 am
Here is what I did. I don't have a picture of of it finished. You can buy EPDM roofing on Ebay by the foot.
KTM_Guy
Images: 193
Re: Piano Hinge
Postby BillD » Thu Mar 28, 2019 3:52 pm
Thank you both for your ideas,
BillD
Re: Piano Hinge
Postby BillD » Thu Apr 18, 2019 5:19 pm
Gday one last question ....I hope
What sealant ,if any do you use under the rubber and around scew holes .
thanks again Bill
BillD
Re: Piano Hinge
Postby KTM_Guy » Fri Apr 19, 2019 8:41 am
I ran a bead of caulk under the rubber but I really don't think is is needed.
Todd
KTM_Guy
Images: 193
Re: Piano Hinge
Postby Shadow Catcher » Fri Apr 19, 2019 5:23 pm
Yes it works.
143018 143019
Re: Piano Hinge
Postby BillD » Fri Apr 19, 2019 6:24 pm
Thanks I thought that might be the case .
ps
My son has a KTMDuke390 in aus
BillD
Re: Piano Hinge
Postby KTM_Guy » Sat Apr 20, 2019 5:00 pm
BillD wrote:Thanks I thought that might be the case .
ps
Those 390 Dukes are so cool. I see 3-4 of them almost everyday now in the Phoenix area.
Todd
KTM_Guy
Images: 193
Users browsing this forum: Google [Bot] and 4 guests
