bdosborn wrote:Woohoo! There's a new battery on the block!
Why do the characters say "Front, Toward Enemy"?
(Just kidding!)
John61CT wrote:The quality internally is a total wildcard with a drop-in, no telling who the actual cell mfg is.
Plus in many contexts only BMS functionality is required, not a single device with that name.
Easy to upgrade / repair too, drop-ins can severely limit current rates.
I doubt you'll get the same decades' longevity out of BB
aggie79 wrote::applause:![]()
Source?
Tom&Shelly wrote:bdosborn wrote:Woohoo! There's a new battery on the block!
(Just kidding!)![]()
rkanz wrote:John61CT wrote:The quality internally is a total wildcard with a drop-in, no telling who the actual cell mfg is.
Do these cells need a BMS and balancer? Who makes a good BMS?
John61CT wrote:The Iota is adjustable right?
Just tweak it until you see no cell goes over 3.5V or whatever your top is.
Don't hand balance low down, do it starting at say 3.4, be consistent.
Then set pack LVC so no cell drops below 3.2V.
Once you have all this setup, the BMS becomes redundant, can try different cheap ones if you like as another layer of protection, but not depending on them.
