My First Foamie
Re: My First Foamie
Postby GPW » Sat Jun 08, 2019 5:33 am
Looks comfortable already … 8)
Re: My First Foamie
Postby Wolfgang92025 » Sun Jun 09, 2019 6:15 pm
looking good.... :thumbsup: :applause: 8)
Wolfgang
Wolfgang92025
Images: 660
Re: My First Foamie
Postby stharding1836 » Tue Jun 11, 2019 1:04 pm
Wolfgang92025 wrote:looking good.... :thumbsup: :applause: 8)
GPW wrote:Looks comfortable already … 8)
Thanks!!!
stharding1836
Re: My First Foamie
Postby stharding1836 » Wed Jun 12, 2019 1:23 pm
Once you start building things out of foam, it's hard to stop. I decided to use the scraps from my camper to start building my kayak.
kayak 3.jpg (46.01 KiB) Viewed 2759 times
Kayak 2.jpg (82.58 KiB) Viewed 2759 times
Kayak 1.jpg (59.02 KiB) Viewed 2759 times
stharding1836
Re: My First Foamie
Postby GPW » Thu Jun 13, 2019 4:57 am
for more foam Kayak building info … https://www.facebook.com/Rowerwet/
Re: My First Foamie
Postby stharding1836 » Mon Jun 17, 2019 9:10 am
The kayak is coming a little faster than the camper.
Kayak 7.jpg (59.67 KiB) Viewed 2687 times
Kayak 6.jpg (59.44 KiB) Viewed 2687 times
kayak 4.jpg (66.31 KiB) Viewed 2687 times
stharding1836
Re: My First Foamie
Postby GPW » Thu Jun 20, 2019 5:25 am
ST , Great idea for a Yak from foam scraps …. Nothing goes to waste !!! … and with some carving and sanding you can make a really beautiful boat for very few bucks !!! :thumbsup: 8)
Re: My First Foamie
Postby stharding1836 » Fri Jun 21, 2019 8:18 am
GPW wrote:ST , Great idea for a Yak from foam scraps …. Nothing goes to waste !!! … and with some carving and sanding you can make a really beautiful boat for very few bucks !!! :thumbsup: 8)
It's starting to look very boat-like. I may be more excited about this than I am the camper.
Waterproofing storage.jpg (64.58 KiB) Viewed 2623 times
Kayak 8.jpg (72.58 KiB) Viewed 2623 times
stharding1836
Re: My First Foamie
Postby GPW » Fri Jun 21, 2019 12:53 pm
WOW!!! Look how Nice that is !!! :thumbsup: 8) :applause:
Re: My First Foamie
Postby stharding1836 » Thu Jul 18, 2019 7:43 am
GPW wrote:WOW!!! Look how Nice that is !!! :thumbsup: 8) :applause:
Thanks, but now I need your painting expertise. I'm using a high gloss exterior paint, but I'm having issues with cracking. Could this be because I'm not giving the paint enough time to cure, or could I be using the wrong paint?
stharding1836
Re: My First Foamie
Postby GPW » Fri Jul 19, 2019 6:49 am
Sounds like you’re putting paint over wet paint that hasn’t had time itself to cure …
Latex paint is curious , It works easy, dries quick all that but in actuality It can take a week or more to properly cure … I know nobody is going to like that news , but if you think about it , if you paint over uncured paint , you have two different drying rates happening :o … a trick the crafters use to get an age cracked antique finish is to apply paint over a layer of not completely dried white wood glue, which dries slower than the paint, so the paint dries quick, remembering it contracts as it dries , a fast drying finish over a slow one , makes the most beautiful antique age cracks … and if you let the glue dry for a couple weeks , then paint over it , it won’t crack at all ..
The idea is with both drying due to exposure to the air , the top film dries quicker , contracts , becomes stable …while the slower drying under layer (less air exposure) is still contracting taking the dry upper film with it = cracking … capisce?
The test , stick your fingernail into the dried paint , if it leaves a dent , it’s still not “cured” …
Painting and covering should be an unhurried process…
Re: My First Foamie
Postby stharding1836 » Sun Aug 11, 2019 7:55 am
GPW wrote:Sounds like you’re putting paint over wet paint that hasn’t had time itself to cure …
I ended up sanding it down and repainting it. It turned out pretty well, but now I’ve decided to go over it with a couple coats of spar varnish to harden it up a little more.
stharding1836
Re: My First Foamie
Postby GPW » Mon Aug 12, 2019 5:04 am
You may want to leave it a couple weeks as it takes that long for Latex paint to really harden … Just sayin’ ... :thinking:
Re: My First Foamie
Postby stharding1836 » Mon Feb 10, 2020 12:06 pm
It's been a while since I posted updates, but here goes. I got the last of the foam on the roof and have now skinned the ceiling.
ceiling skin 4.jpg (63.79 KiB) Viewed 1828 times
Ceiling skin 3.jpg (157.09 KiB) Viewed 1828 times
ceiling skin 1.jpg (68.65 KiB) Viewed 1828 times
stharding1836
Re: My First Foamie
Postby stharding1836 » Mon Feb 10, 2020 12:08 pm
I also added back support to the dinette and made the cushions.
Dinnette table.jpg (187 KiB) Viewed 1828 times
dinnette no table.jpg (190.05 KiB) Viewed 1828 times
dinnette bed.jpg (198.1 KiB) Viewed 1828 times
stharding1836
