Atomic77 wrote:Glad you're back in action! Very nice design, which I wouldn't expect any less from you Oleg. Keep the progress and the pictures coming!
Sent from my SM-N950U using Tapatalk
I didn't come up with this originally, maybe captain telescope? I did it the first time according to my plan. Then I did it a second time because the first plan didn't work! (Or something to that effect!) Trust me you aren't alone. There's a good reason most of the campers in the world were built in factories! Lol! On our race boats we used a windshield sealant made by Fastenal. It's the only thing we trusted on the F-16 cockpit windshield of tge race boats. In comparison, 5200 is about $26 per tube here. The Fastenal sealant was upwards of $60+. But, worth it. Basically water and heat proof. And black.OP827 wrote:I was actually thinking 3M 5200 as well, thanks Michael. This 5200 adhesive is quite expensive here and not off the shelf, but the rework is even more expensive. I will check PDS for windshield adhesive from local auto supply for comparison and then decide. And there are some pictures of the failed test just for entertainment
I laid the windows down for testing on the hot tub and they buckled and come apart within 10-15 minutes! The adhesive cured for almost a week for all windows except three, but the new ones just came apart 5 minutes quicker than others. This adhesive is not good for this application. A the time of shopping for adhesive I did not think of high temperature during use, while I should have. Live and learn. There is also significant stress on the adhesive joint due to the window higher thermal expansion comparing to wood frame.
Atomic77 wrote:Personally I'm a believer in 3M 5200 for just about anything you don't want to come apart. The spec sheet says to 190° F but that's for tensile strength. It will remain solid well over that.
Only thing is its white
OP827 wrote:Atomic77 wrote:Personally I'm a believer in 3M 5200 for just about anything you don't want to come apart. The spec sheet says to 190° F but that's for tensile strength. It will remain solid well over that.
Looks like it can be black:
https://www.amazon.ca/3M-Marine-Adhesive-Sealant-06504/dp/B001R0GUZG/ref=sr_1_1?keywords=3m+5200+black&qid=1560026733&s=gateway&sr=8-1
One of the things that Carrie and I always talked about while building our camper is, a factory would do R&D, build a prototype, iron out the bugs through multiple processes then finally come up with a completed part. In our case, we had to do all of those things in one try and get it right the first time because we couldn't afford to make mistakes! There's the challenge of it!OP827 wrote:Agree Michael, build technology in a factory would be tested and proven by prototype before going full scale commercial. I do not want to sound like Captain Obvious, but they would not be in business, if they do not engineer and test their products. I am thinking the windshield adhesive would be more suitable, just because of the high temperature, but will compare by Product Datasheets. I am OK with failures, this trailer build is like a Test Laboratory, I am sure something else would fail or come apart. Happy building!
S. Heisley wrote:If you have to remove or replace a window, be aware that 3M 5200 is pretty much permanent; so, removal of something attached to wood will tear the heck out of that wood, even painted wood. (Been there, done that.) 3M 4200 is a little bit easier on the wood frame and will still hold well, IMO. It seems that maybe windshield adhesive might work, though. If you can, try using some on some scraps and see how it does and what happens when you try to tear them apart.
