Hi Kristaology,kristaology wrote:Beautiful woodwork!
I'm curious, it looks like your walls are sitting on top of the floor. How did you secure them down? I'm following the same build plan and need ideas that don't involve throwing a dowel rod on my floor.
Sent from my LGL83BL using Tapatalk
That's pretty much how I was thinking of attaching my walls, except from the inside. How does it feel structurally when the spars are in place?
Thank you so much for showing both ways! Very helpful pics!tony.latham wrote:That's pretty much how I was thinking of attaching my walls, except from the inside. How does it feel structurally when the spars are in place?
I've done it both ways.
On this current build, I'm doing it from the inside since the exterior will be glassed and then covered with Monstaliner.
I use PL Premium adhesive on this joint.
I'll butt screw from the side and then add the pocket screws. Part of the structural strength is from the roof/ceiling joint at the front and the rear bulkhead that gets screwed to the floor.
Rock solid.![]()
Thank you for pointing this out! I've been thinking about it all night and all morning lol. I texted my dad about it and he said that he DOES worry about it! Never mentioned it to me though lol. Here's our conversation in typical dad response format. Ultimately we are just going to roll with our original plan and I'm going to take the "probably" as good enough because we've come too far to change course now. I'll probably call him later today to have a real talk about it, but I think we're going to plow on ahead.campbellinaz wrote:Keep in mind that using sheet goods (at least on one side) are key to a sturdy build. Sheeting one side of the framing will create shear strength and prevent “racking”, the same principal in home construction (ask your Dad). I would be very hesitant to use t & g on both sides for this reason. Even the simple old travel trailers used paneling on the inside (creating shear strength) and overlapping metal “bands” that were corrugated (for strength & rigidity) on the outside. Good Luck !
