In the past week, I glued blocking around the hatch ribs (1/2" plywood), and custom cut and installed blocking for the tail lights, license plate holder, dome light, and hatch handle:
![158337](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=158337)
After doing all of that, I realized that I'd installed two of the ribs slightly cock-eyed! How could I be so stupid?
![Embarassed :oops:](./images/smilies/econ_embarassed.gif)
(What, me worry?)
The rib holding all the blocking is 3/4" low on one side, as is the one above it. The third one is straight. To answer my own rhetorical question, I think I measured from the bottom for the two cock-eyed ribs and measured from the wrong place. Since I custom fit all the blocking, I never noticed.
I think it will be okay. Since this is a Benroy, the lower cock-eyed rib is on the flat vertical part of the hatch, so it shouldn't matter. The other cockeyed rib might, but we'll try skinning the inside this weekend, and if it looks okay, we'll leave it alone. I could cut it out and replace, but will need some more blocking which would add weight. If we get away with it, after skinning, it won't show.
![Worship :worship:](./images/smilies/econ_worship.gif)
We did get the air compressor Shelly inherited from her Dad working, and tested our 23 gauge pin nailer. Looks like it will work fine, so my plan is to cut 1/8" Baltic birch and use it to skin the inside of the hatch (as well as the outside eventually). I wanted access to the wiring for the lights, and so we plan to glue (with PL Premium) the inside skin to the curved part of the hatch. The lower part, between the bottom and the first rib, we plan to screw on, and so it will be removable. If you look close, I glued a 3/4" by 3/4" strip of poplar above the rib, to hold the edge of the upper skin, while the lower one screws to the rib. After I finally measured and realized my mistake, I glued a second 3/4" by 3/4" strip above that one, so we can cut the access panel straight across.
These are the tail/brake/backup/turn signal lights we plan to use:
![158331](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=158331)
Right after noticing my cock-eyed ribs, I realized we have a problem with these as far as splitting the right turn/brake and left turn/brake wires from the TV into separate brake and turn signals. Found a device that does that on E-Trailer, but the specs say it's for incandescent bulbs only. I posted some questions on the electrical folder about that.
I still need to make a bracket for the center stop light, by the way. Not sure how we'll do that, but a 45 degree cut with the table saw is likely in the future. A block of wood with a pleasing shape protected with epoxy, along with an epoxy fillit to the fiber glassed outer skin is a likely possibility.
Shelly was afraid that if we center the license plate, someone might someday scrape their hands on the edge of the plate reaching for the handle. Two solutions came to mind: the first was a license plate frame that reads: "We have a retirement plan, we plan to camp", the other solution was simply to move the plate to one side. This is the license plate holder we have
![158333](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=158333)
The California plate is simply for fitting. I've lived in half a dozen states, and have plates from most hanging in the shop. As an aside: Shelly was an elementary/middle school teacher in New Mexico, and they don't teach kids cursive writing here anymore. So evidently, they wouldn't know this is a California plate!
