Yeah in going over it in my head 1000 times, that was my biggest question with your set up. Is there enough separation between intake and exhaust. I've see some run the intake through a roof vent, but I didn't really want to cut my roof. I've seen others install little computer fans to push the air around too. Not sure if that's needed or not. The ac is my next project, so it's consuming my thought process currently.Karebru wrote:The AC shroud still needs to have baffles installed that separate the in and out flow of the outside air. It also needs weather stripping around the inside opening.
I haven't really tested it yet.
It's a variation of what several guys here have done. I'm trusting their experience.![]()
Not a whole lot going on with my camper lately. I've been fiddling around with the plumbing a little bit.
Finishing that up is probably my next step.
Karebru wrote:XR-duous, flboy (Don) is the one who gave me the basic idea and explained the need for baffles.
I'm with you, though. I didn't want to cut holes in my roof. I know, if it's done properly, but...![]()
One thing I did do, was make my shroud big enough to step up a size on the AC, in case the 5,000 doesn't do the job.
XR-duous wrote:Yeah, i was wondering about the floor option, but with the ac unit up high and creating ducts for intake and exhaust through the floor.....or just the intake. My concern was that it would be too far to draw air properly.
Sent from my SM-G960U using Tapatalk
flboy wrote:Karebru wrote: I didn't want to cut holes in my roof.
there is another thread, and I can't remember the name off the top that has it all in and out through the floor for stealth reasons. Another creative solution and, as I remember, he said it worked well with the only drawback needing an fan in the cabin to stir the cold air that was all at floor level to start and then it would cycle off due to location of thermostat at the floor level with the colder air staying low... but there is a hack to move that from the AC unit itself if you wanted.
