Finally underway with our 7X14 V-nose conversion
Re: Finally underway with our 7X14 V-nose conversion
Postby wyldesyde007 » Wed Jun 19, 2019 7:08 pm
I got the shower pan dry fitted tonight, it's 3 layers of fiber glass for a grand total of 1/8" thick. I laid a couple of the raised floors tiles in to see what they'll look like
Sent from my LG-H910 using Tapatalk
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 23, 2019 3:28 pm
Today's project is getting the through-wall fan installed for the bathroom, you may remember from an earlier post that I was trying not to put any more penetrations in the roof than I had to. It took me a while to find a fan I felt would get the job done.
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 23, 2019 5:51 pm
This fan is a bit bigger than I was hoping to find but in the end I believe it'll be better because it moves a whole lot of air :D
You can see here I'm doing a little exploration cuts to find a good place to cut.
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 23, 2019 5:54 pm
Well it never fails...
Here's one of those things you can run into when purchasing a prefabbed trailer, you don't know where they ran all the wiring!!
wyldesyde007
Images: 131
Postby featherliteCT1 » Sun Jun 23, 2019 5:56 pm
You shall overcome :twisted:
featherliteCT1
Postby wyldesyde007 » Sun Jun 23, 2019 5:57 pm
I got the wire moved without too much fuss and finished the exterior cut.
And got the fan mounted! 8)
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 23, 2019 6:06 pm
When I bought this fan the description stated that it did both exhaust and intake and I wondered how that was possible considering the louvers. Turns out after I received it I found out that when you pull the switch cord it mechanically opens the louvers :thumbsup:
Here's a link to a video of it working https://youtu.be/C1OOearOGSU
wyldesyde007
Images: 131
Postby wyldesyde007 » Mon Jul 01, 2019 6:51 pm
The fan you purchased didn't come with an exterior trim ring? Just print one!
That's the beauty of owning a 3d printer 8)
wyldesyde007
Images: 131
Postby Carolina_coast99 » Mon Jul 01, 2019 8:56 pm
wyldesyde007 wrote:Today's project is getting the through-wall fan installed for the bathroom, you may remember from an earlier post that I was trying not to put any more penetrations in the roof than I had to. It took me a while to find a fan I felt would get the job done.
I am enjoying reading and viewing your build. Could you possibly provide a link or info on where to purchase- on the through wall fan?
Thank you
Carolina_coast99
Postby wyldesyde007 » Tue Jul 02, 2019 5:15 am
Thank you
Certainly!
Double-Purpose Ventilation Exhaust Fan,110 Volt Reversible air Ventilation Fan,Ventilation Fan for Kitchen Bathroom, Wall-Mounted Exhaust Fan with 180 https://www.amazon.com/dp/B07PH77ZHX/re ... 4J1SzjChwD
wyldesyde007
Images: 131
Postby wyldesyde007 » Tue Jul 02, 2019 11:08 am
And here's the link for the trim ring files if anyone ends up purchasing this fan.
Vent fan exterior trim ring found on #Thingiverse https://www.thingiverse.com/thing:3725739
wyldesyde007
Images: 131
Postby McDave » Tue Jul 02, 2019 12:17 pm
Really sweet fan. Wish I had seen that while I was in the planning faze. But I think I am done cutting holes for a while.... Maybe? :NC
McDave
McDave
Images: 412
Postby wyldesyde007 » Tue Jul 02, 2019 6:41 pm
Tonight I've been finishing up the "padding" on the shower walls to flush them up with the edge of the shower pan, this will let the FRP lay relatively flat as I extend it down into the pan.ImageImageImage
wyldesyde007
Images: 131
Postby wyldesyde007 » Tue Jul 02, 2019 6:49 pm
Here's a tip that may have been shown already.
Use metalized duct tape as flashing behind your corner joints! It's wider than the standard corner trim used with FRP and you can extend it down into the pan for effective drainage 8)
I started by folding the tape in half
then peeling back a small section of the backing on one half I pressed it into the corner slowly working my way down
I'd peel another small section until one side was completely stuck.
The remaining side I just peeled the entire length and carefully pressed it into place.
wyldesyde007
Images: 131
Postby hankaye » Wed Jul 03, 2019 6:01 am
wyldesyde007, Howdy;
Been following this forum for several years now and feel fairly sure that
this is the first time anyone has taken the time to show & tell that tip.
Handy as all get-out.
:thumbsup: , :thumbsup: !
hank
hankaye
Users browsing this forum: Bing [Bot] and 5 guests
