Guys, As a professional Artist for 50 years now , we’ve prepped and painted a lot of Canvas over the years … disclaimer: We kept them
inside under stable conditions … the remaining ones not sold off are still like new !!! We’ve always followed the idea of a stretched canvas needing a “sizing” coat to “seal" the individual fibers to prevent rotting or being affected by the top coats of paint .( My artist Oil paints tends to rot unprotected canvas over many years, why we size and prime ... ) Traditionally “Rabbit skin glue “ ( hide glue ) has been used for that , but with the advent of Acrylic paints , the Acrylic primer will perform the same function … The trick is Diluting the paint so it can seep inside and encapsulate the fibers. We’ve been doing it for years , just as we’d dilute an enamel, alkyd or lacquer… The trick is to only dilute it enough for the job you’re doing ...
Paint is basically just Three materials … The Pigment (coloring) , the Glue to hold the pigment together ( binder ) and the solvent to thin it and clean up ..Other ingredients may be added for various reasons . ( fungicide , UV resistance , etc. )
Thee real story with thinned glue ( or paint) is that , sure it’s going to lose Bonding strength because the glue molecules are diluted , not as if the molecules lose any strength , but with the added solvent ,
they are further apart ( Capisce ? )
Primer is mostly Paint with
lots of Titanium Dioxide ( Pigment ) to make it thick and better “covering” ,and a good smoother surface for the final paint colors . That thickness prevents the protective sizing primer from really soaking into the fibers , so we thin it ( solvent ) … Naturally once "sized“ The canvas can be conventionally primed with undiluted Thick primer . So thin away as to your needs … IT’s OK !!!
Glidden vs PPG ??? … That remains to be tested over Time , but I’m sure both are good as Primers and attaching canvas … For other properties like sticking to metal or other plastics , we know that’s gotta’ be tested too. Like Dave said ^ “ To tell the truth, for me, the experiments are half of the fun.
![Very Happy :D](./images/smilies/econ_goldtooth.gif)
