Lifting roof XPStream - making improvements
Re: Foldable foamie hybrid trailer - XPStream
Postby OP827 » Sun Jul 28, 2019 6:51 pm
Good to know, thanks. A little video just to see how it works: https://photos.app.goo.gl/pinSN6RP69SUhoQu8
OP827
Images: 414
Postby Atomic77 » Sun Jul 28, 2019 7:27 pm
OP827 wrote:Good to know, thanks. A little video just to see how it works: https://photos.app.goo.gl/pinSN6RP69SUhoQu8
That's fantastic! The split door adds another element of coolness! Well done!
Sent from my SM-N950U using Tapatalk
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby OP827 » Sun Jul 28, 2019 7:38 pm
:thumbsup: Thanks!
And closing down: https://photos.app.goo.gl/bsfPYJoBFavL9tAg9
OP827
Images: 414
Postby Atomic77 » Sun Jul 28, 2019 8:00 pm
Thanks!
I'm surprised at how fast it is.
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Sun Jul 28, 2019 8:08 pm
Thanks!
Fast is more fun, right? 8) :D I can always slow down the drill or motor to do it slower... But I like it like that.
OP827
Images: 414
Postby Atomic77 » Sun Jul 28, 2019 8:18 pm
OP827 wrote:
Thanks!
I wish my actuators on my TV and. Bed were faster. But I'm guessing what you have are much different.
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Sun Jul 28, 2019 8:26 pm
Atomic77 wrote:
OP827 wrote:
Thanks!
I used to have an electric actuator, but decided to go mechanical only for more reliability. It is a drive screw with a ball nut from this Coleman donor tent trailer.
OP827
Images: 414
Postby OP827 » Thu Aug 01, 2019 7:30 pm
Just ordered this fan, 1200 basic version. Will install in the folding wall behind the gas stove.
https://www.amazon.ca/gp/product/B0027XAN78?ref=ppx_pt2_dt_b_prod_image
OP827
Images: 414
Postby Atomic77 » Thu Aug 01, 2019 8:54 pm
OP827 wrote:Just ordered this fan, 1200 basic version. Will install in the folding wall behind the gas stove.
I'm pretty sure that's my fan. I'll be honest about it. It's simple, no frills and functional. It draws air hard! You'll be surprised. And I like the fact that there is little to go wrong with it. I have two and have been very pleased.
Let me know how it goes. I think you'll be happy with it.
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Thu Aug 01, 2019 8:57 pm
Did you have any issues with manual crank handle? There were negative reviews for the light duty design oof it.
Sent from my Moto G Play using Tapatalk
OP827
Images: 414
Postby Atomic77 » Thu Aug 01, 2019 9:01 pm
I haven't had a single bit of trouble with any of it. But I take care of my stuff and treat things nice, ya know? I mean, they are just plastic so if you are reckless, then i guess... but i have had zero issues. I just took both of mine apart today and cleaned them. Like new again.
Michael
The Astroliner
Atomic77
Images: 309
Postby Atomic77 » Thu Aug 01, 2019 9:03 pm
Oh. And side note. I had one, and bought a cheaper brand for the bathroom. I honestly couldn't believe the difference in the two! The Fan-Tastic fan was leaps and bounds ahead of the other brand. I didn't even camp one time and I had already bought a second Fan-Tastic and swapped out the cheaper one.
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Sat Aug 03, 2019 9:01 pm
Continued paint spraying today. Final primer coatings on access doors, entry door and side walls are done. Did not take pictures as they look the same as before except with added urethane reducer the coat came out nice and smooth. Tomorrow I plan on removing the roof for the first time off the trailer and attempt to prime it, will see how that goes.
OP827
Images: 414
Postby Atomic77 » Sat Aug 03, 2019 9:36 pm
Glad it went better for you. Les of money and chemists came up with the formula for a reason. Lol. Mix it exactly according to the instructions. Probably 4•1•1. Good luck!
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Sat Aug 03, 2019 9:52 pm
Atomic77 wrote:Glad it went better for you. Les of money and chemists came up with the formula for a reason. Lol. Mix it exactly according to the instructions. Probably 4•1•1. Good luck!
Yes, that is what I did and the high build surfacer/primer was laying down wet and smooth. What grit to use on final primer before base coat, 600?
OP827
Images: 414
