Prototype. More data is needed about run time.
I think it will work.
=Cosmo
Cosmo wrote:[color=#0000BF][size=150]Prototype. More data is needed about run time.
=Cosmo
TimC wrote:Cosmo wrote:These small fridges do not have a fan in them to circulate air.
https://www.amazon.com/gp/product/B01E5 ... UTF8&psc=1
Cosmo, I like the idea of a small fan. I'm curious if one of the below fans with some fabrication of a case would work to circulate air in the fridge. I get that I don't want massive air movement. This one has 2.3 cfm which is even higher than necessary I think. What do you think? I'm a tinkerer and don't have any problem either wiring with a battery (there are many small 12v batteries on the market) or wiring direct to the input to the fridge, or, there are versions of this that are 5 volt. I've also run an 12v, 80mm case fan on a 9v battery with sucess. This fan runs on 6/100 amp, so, I think it would last quite a while on a charge. Maybe even one of those rechargable battery packs that you use for a phone backup. OK, I'm rambling. Can you tell I like the idea of adding a fan to the fridge?
https://www.ebay.com/itm/12V-25mm-Mini- ... 0047.m2108
Tim
Or just get thisTimC wrote:
