#4
Re: #4
Postby campbellinaz » Mon Aug 05, 2019 8:32 am
Enjoying following your build Tony! I’m currently in the midst of a build and pricing out sheet aluminum in the Phoenix area is crazy expensive! I’m in need of 5x10 sheets which I’m told are only available in .063 and I’m seeing prices just shy of $300/sheet . So I’m looking at “liners” now as they are much less expensive. Although glass/epoxy is far more time consuming it can’t be as expensive as 3-4 sheets at $300 a copy.
campbellinaz
Re: #4
Postby tony.latham » Mon Aug 05, 2019 9:29 am
I have not looked at the cost comparison yet but I will at some point.
.06 aluminum is going to be stiff.
So far the fiberglassing has been quick and easy. The roof and edge tape will be a bigger job but I’m anticipating two hours.
T
Re: #4
Postby Tom&Shelly » Mon Aug 05, 2019 7:44 pm
tony.latham wrote:We're leaving in the morning for a four nighter on a fire lookout so I've got time to think. :frightened:
So, I meant to ask earlier, but are you officially looking out for fires? Is that a volunteer activity?
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Re: #4
Postby tony.latham » Mon Aug 05, 2019 7:49 pm
Yes.. truly in the middle of nowhere. An hour hike to the truck and then an hour to pavement. Deep in the Selway Wilderness. We’ve not spotted a fire but a lookout to the east called one in.
Two more nights. And the Aurora is forecasted tonight.
T
Re: #4
Postby Squigie » Mon Aug 05, 2019 9:10 pm
That should be enjoyable.
I spent some time on the Selway and Lochsa rivers last year, for the first time.
I need to get back there.
...Maybe next spring, so the kids can see the rivers at high water. (Last year was very impressive, even for "little" rivers.)
Squigie
Re: #4
Postby Tom&Shelly » Tue Aug 06, 2019 5:55 am
T
Now that's cool! :thumbsup: :thumbsup: :thumbsup:
Hope you saw the Aurora!
Tom&Shelly
Images: 2282
Re: #4
Postby tony.latham » Tue Aug 06, 2019 11:43 am
T
It was a green hue just above the saw blade of the Bitterroot peaks.
I think the forecast is the same. Perhaps the shimmering curtain will dip farther south tonight.
T
Re: #4
Postby KTM_Guy » Tue Aug 06, 2019 2:46 pm
campbellinaz wrote:Enjoying following your build Tony! I’m currently in the midst of a build and pricing out sheet aluminum in the Phoenix area is crazy expensive! I’m in need of 5x10 sheets which I’m told are only available in .063 and I’m seeing prices just shy of $300/sheet . So I’m looking at “liners” now as they are much less expensive. Although glass/epoxy is far more time consuming it can’t be as expensive as 3-4 sheets at $300 a copy.
Don’t go to IMS, I found a place and got .040 5X10 I think was $60 a sheet. Can’t remember the name right now. It was west of downtown.
Todd
KTM_Guy
Images: 193
Re: #4
Postby KTM_Guy » Tue Aug 06, 2019 3:11 pm
Don’t go to IMS in PHX, I found a place and got .040 5X10 I think was $60 a sheet. Can’t remember the name right now. It was west of downtown.
Todd
KTM_Guy
Images: 193
Re: #4
Postby tony.latham » Tue Aug 06, 2019 4:17 pm
Todd
You should try and talk Todd into a tear tour. A remarkable build.
T
Re: #4
Postby tony.latham » Fri Aug 09, 2019 5:29 pm
Turned another corner today. The roof is on.
Is it possible to build a teardrop without a 1/4" crown stapler? :thinking:
Oh-no! The dreaded hatch is next! That curvy thing that makes teardroppers shudder with fear! Oh-my! :frightened: :frightened:
Re: #4
Postby OP827 » Fri Aug 09, 2019 6:23 pm
tony.latham wrote:Turned another corner today. The roof is on.
Looks nice! Did you glue the ply down with PLP?
OP827
Images: 414
Re: #4
Postby tony.latham » Fri Aug 09, 2019 7:03 pm
Yep. The brown goo.
Working on the hatch gusset template at the moment.
T
Re: #4
Postby tony.latham » Fri Aug 09, 2019 9:13 pm
I managed to crank out the hatch gusset template tonight and the template for the spacer.
The spacer gives me 3/8" of room for my 1/2" seal. :thumbsup: An 1/8" of squeeze.
T
Re: #4
Postby tony.latham » Sun Aug 11, 2019 1:04 pm
What time is it on the Shop Clock???
It's HATCH-ZERO-DARK-THIRTY! :shock: :? :frightened: :NC (Background music: Dun-dun DUNNNN!)
:frightened:
p.s. Here's how I've attached the upper strut bracket:
