Modstock wrote:People tend to go a bit overboard with "off-road" . Which really isn't needed.
My standard teardrop does just fine with slightly bigger tires 5.30/12".
I never take it on a actual 4wd trail , it gets parked at camp and then I go jeeping.
Usually when I am on a rougher dirt road with miles to go I'll air the tires down to 25 psi to smooth out the ride along with the jeep tires.
Sent from my H1611 using Tapatalk
campbellinaz wrote:... I wish I had built a box with 3/4” ply and then sub-framed on the inside for insulation, wiring and sheer. Would be a far easier, less time consuming and cheaper approach. Oh yeah, and lighter! I’d love to know how many pounds of Kreg screws I’ve used. Lol
slowcowboy wrote:... Build like a tank you wont regreate it 10 years later of off road travel....
working on it wrote:campbellinaz wrote:... I wish I had built a box with 3/4” ply and then sub-framed on the inside for insulation, wiring and sheer. Would be a far easier, less time consuming and cheaper approach. Oh yeah, and lighter! I’d love to know how many pounds of Kreg screws I’ve used. Lol
* I did build my box with 3/4" plywood, and sub-framed the doors windows, along the beltline inside (to support windows and shelves), and on both sides of the A/C cut-out in the rear bulkhead, with 1/2" x 3" wide red oak. No insulation (I would insulate it if I was to build again, but not a necessity here in N.Texas), and the wiring is semi-exposed (for simplicity and ease of repair).
* Lighter? not the way I doubled-up on PL adhesive, used 1/4"-20 stainless bolts everywhere (I bought lots of pounds in weight & hundreds of $$ in stainless carriage bolts alone), and always used more critical hardware than most anyone would do (hinges, where two would do, I used three; always doing the same for door locks and hatch hardware). And, I used 3/4" plywood for the galley shelf and inside overhead stereo shelf in the cabin, and 1" thick for the fold-down shelf on the inside bulkhead. Nothing is lightweight.
* But, if I had bought 1/2" ply, as I had set out to do, then maybe I would've/could've brought the build in at a more reasonable weight. When I realized that it wouldn't be towable by my smaller vehicles (with 1000 lb tow limits), then I went all-in, and built for durability and strength, instead. Towing with overbuilt pickups (one regularly towed 8000 lbs...capable of 12k, and the other 6000...capable to tow 10k, hauling drag-racing cars) made that decision not unreasonable. At least to me.
* Luckily, I made that decision before I extended my frame, and used rectangular tube steel, instead of C-channel, and used 3" square tubing to replace the 2" that had been bought for it. The single beam tongue was sistered to a central spine, that was extended to the rear, also, and the tongue is welded to three cross-members. The only weakness was trying to stay with a questionable-strength axle, which I intended to replace eventually, and did so a year later (reinforcing the frame at the same time).
* Though I probably will never off-road with it, I have brought it up to that capability-level over the years. I say go all the way towards your planned goal for your trailer...use no stop-gaps or substitutes for what you need, and you'll be happier for doing so.slowcowboy wrote:... Build like a tank you wont regreate it 10 years later of off road travel....
