XR-duous wrote:This is on my list for sure. Once I get it fully built I plan to head up empty and then loaded. I'll use the numbers to better determine tongue weight and tire pressure. Did you have to unhook the trailer from the truck?
Sent from my SM-G960U using Tapatalk
booyah wrote:860lbs for smiles to go. Weighed it on the way home from a trip, so it had a half full cooler, but was otherwise loaded for war
Vtec44 wrote:booyah wrote:860lbs for smiles to go. Weighed it on the way home from a trip, so it had a half full cooler, but was otherwise loaded for war
Oh wow! You can pretty much tow that with anything!
Vtec44 wrote:... and it happens to have a scale so I went on it to weigh my trailer. She's just over 2100lbs. Have you officially weigh your trailer? It was a lot easier than I expected. It felt so weird pulling my tiny trailer next to a bunch of big rigs.
gudmund wrote:my 5x8 tear - empty was 1150 lbs (with the spare mounted) and 1440 lbs loaded (+the 160 lbs tongue weight puts it at 1600 lbs total ) Have used 'many' of my states weight stations after hours and what has impressed me is that they have all 'agreed' with each other - along with the ones in the state of Oregon agreeing also!! (the difference between them is Washington's are in 20 lb increments and Oregon's are in 50 lb increments) And YES mine has trailer brakes!! ............................
