But , There ya’ go !!! The real Truth of what’s happening !!!
Big Thanks Fish !!! Guys , seems like the bottom line is , if you really like the Gripper original , better stock up … it's out there somewhere … for now …
zzzizxz wrote:I'm interested in that aluminum paint, or other options. Definitely looking to hear what other people have found.
Personally, I wish I hadn't used PPG gripper. The areas I used it have not stuck as well as the spots I used Glidden. It just isn't as good, and I have had more issues with bubbling than I think I should.
Hindsight being so good and all, I don't think I would recommend the new version to anyone. Just my thoughts.
RJ Howell wrote:zzzizxz wrote:I'm interested in that aluminum paint, or other options. Definitely looking to hear what other people have found.
Curious if you tried it straight? No mix.. Seems to me the bubbling is coming from mixing.. I'm so close to covering and searching for a good solution (pun intended).
zzzizxz wrote:
ghcoe wrote:On my builds I did primer the exterior before the canvas process.
I primed since I do a lot filling with spackle and once I get the surface smooth I prime the area before adding any more spackle. Keeps me from sanding too far into the surface. One I am done filling I prime the whole exterior. TBII seems to bond just fine to the primer.
Users browsing this forum: jgmahoney and 11 guests
