Ned B wrote:+1 subscriber
ghcoe wrote:Got the other roof piece kerfed today.
The first piece is glued and dry.
My GS ran out of pressure so I had to switch over to GG to finish gluing the two pieces together. I had just enough pressure to finish the outside perimeter with the GS
zzzizxz wrote:ghcoe wrote:Got the other roof piece kerfed today.
Hi @ghcoe, I know this is a really old thread, but I was wondering what you glued to laminate the two roof panels together. I'm going to be at this stage on my own build in a bit, and was wondering.
Did you apply GS (until you ran out) to the whole bottom sheet, or did you just spray it into the kerfs, or did you just go around the edges?
Also, if you did apply it to the whole sheet, how did you do that? Do you just spray some on and use a brush to spread it around Were you concerned with the GS expanding and buckling the two sheets in the middle, or does spreading it keep it from expanding so much?
Thank you!
pchast wrote:What kind of wire are you using in the solder gun for a cutter?
How thick is it? I haven't found anything that won't bend when
heated yet.........
Thanks for the info.
