HF welding machine ???
Re: HF welding machine ???
Postby GPW » Wed Oct 09, 2019 4:45 am
GPW wrote:Guys , Thanks !!! I basically need to weld in some thin metal , mostly for tacking in replacement body panels , then welding solid with my friends Tig … I didn’t want to invest in a more pricy unit , just a little 110V “DC” model for this project . < $200.00 ( on sale )
Thing is ... I Know how to weld , although not a “welder” … I already have a big welding machine (stick) , My friend has a TIG machine …
The reality is , I have a limited amount of MONEY ( OLD, fixed income) and need a small uncomplicated Temporary MIG to just do some tacking ( little tiny dot welds) of sheet metal on my car project . That’s ALL !!! … Once tacked on , I’ll weld it up solid with my buddy’s quality TIG machine … :thumbsup: Once done , the cheap machine will likely get put on a shelf and never get used again … ( another dustcatcher for the estate sale ) Any ideas … ??? :thinking:
Postby RJ Howell » Wed Oct 09, 2019 7:18 am
I liked the thought of Craigslist and found this in my area. https://nh.craigslist.org/tls/d/center-barnstead-hobart-handler-120-mig/6984342832.html
Could something like this, with the gas, step up to welding 3/16"- 1/4" steel?
Don't wish to side track your thread in asking this question. Also wonder if this would meet your needs and go further for the dollar.
RJ Howell
Images: 36
Postby twisted lines » Wed Oct 09, 2019 9:21 am
RJ Howell wrote:Could something like this, with the gas, step up to welding 3/16"- 1/4" steel?
This one is rated 3/16" MAX; Max I would use it on is 1/8" It would work great for the OPs needs, Tank not included $$$ if desired.
Somthing to pay attention to is will it run on 15 Amps, One that I owned Only ran with 20 A, This one say's 20A in the manual as well.
Racking up; And Rapin foam
twisted lines
Postby tony.latham » Wed Oct 09, 2019 9:40 am
According to the manual, my Hobart 140 is limited to 3/16". But I feel comfortable welding 1/4" with it.
Here are two examples. The upright receiver and the jack bracket:
Postby retep » Wed Oct 09, 2019 10:42 am
Sorry to jump in, Tony did you use argon with this weld or just flux core?
Thanks
Peter
retep
Postby tony.latham » Wed Oct 09, 2019 10:49 am
retep wrote:Sorry to jump in, Tony did you use argon with this weld or just flux core?
Thanks
Peter
I've got a CO2 bottle on that welder but for whatever reason, I do better with flux-core wire and no gas. Flux core.
Postby twisted lines » Wed Oct 09, 2019 12:55 pm
Three things Come too mind
1. Sorry about off topic
2. Tony are you changing the polarity between the two diferent set ups ?
3. The mixed gas costs a little more but runs so much better, and it does help the flux core penetrate more with out slag.
twisted lines
Postby Philip » Wed Oct 09, 2019 12:59 pm
If your on face book the market place has some good deals on welders at times.
Myself I would not look for any welder under 140 amp rating. All the little cheap welders you see at 100 amp or less. I have found them about useless. Get a mig with gas. If your planning to paint when your done. Your chances of getting the welding flux out of a flux core weld might be slime or none.
What panels are you replacing on the car?
Philip
Images: 323
Postby tony.latham » Wed Oct 09, 2019 3:41 pm
Yes. I'm wondering if it isn't my cheap regulator.
T
Postby NevadaBlue » Wed Oct 09, 2019 4:47 pm
I have a HF Mig (and a TiG) and both work fine.
Are you working outside? A breeze will blow the shield gas away. I use a stick welder if I have to work outside and there is much breeze. That may be why your flux core is working better.
Ken
NevadaBlue
Postby GPW » Thu Oct 10, 2019 4:14 am
Philip asked .. “ What panels are you replacing on the car? “ Things like this … cutting out rust replacing the rusted area with clean metal . Sorta like this ..( see pic ) … all just thin metal ( not as thin as new cars ) I just want the MIG for tack welding the panels on , and will finish with a friends TIG …
Postby Philip » Thu Oct 10, 2019 6:02 am
I would still look for a 140 at the smallest. I have welded many hundreds of hours on many different welders. I have found many of the low end welders have problems with the mig liners. Poor quality right out of the box. If it will not feed wire properly you won't even tack weld. If I was looking for a welder used or new. I would be looking in the Hobart/lincon /miller brands. Stay way from a Clarke brand. I haven't found one of them yet that will run at top rated amps.
Another reason I am saying 140 amp. Most of them run .035 wire. That I the easiest wire to find. If you get one using .020 or .025. A lot of places might sell the welder. But they do not sell the wire for it.
Inner wheel house. You got some work there.
:frightened:
Philip
Images: 323
Postby tony.latham » Thu Oct 10, 2019 9:30 am
I think Youtube is DIY University.
I think it would work fine for what the OP wants to do.
Postby Modstock » Thu Oct 10, 2019 12:15 pm
I run a small Lincoln mig (150 I think)
My dad couldn't get to run properly.
Gave it to me and converted it back to gas and tuned it up. Works great.
Seems to run best on 0.30 wire but cant find that near me. HF has only been restocking the 0.35 wire in the small spools. Not sure if I can fit a 10lb spool inside.
Sent from my H1611 using Tapatalk
Modstock
Postby twisted lines » Thu Oct 10, 2019 5:04 pm
Modstock wrote: Not sure if I can fit a 10lb spool inside.
If you still have a adapter like this it will , but the little bugger just gained 10 lb's :lol:
I prefer the .030 wire as well .
twisted lines
