Is floor insulation necessary ?
Postby LostBob » Mon Sep 16, 2019 5:54 pm
I plan on building a square back next year. Is floor insulation necessary if I'm not winter camping ? I plan on three season camping in the Great Lakes region. The mattress will be at least 6" of foam. The walls and ceiling will be insulated.
LostBob
Re: Is floor insulation necessary ?
Postby Woodbutcher » Mon Sep 16, 2019 6:34 pm
No, I did it in my first one and not in the next three. I camp down to freezing with no issues.
Woodbutcher
Postby tony.latham » Mon Sep 16, 2019 6:40 pm
If you are losing BTUs through the floor, you don't have enough mattress.
But --on this latest build, the floor that is 1/4" bottom, 3/4" skeleton framing with foam board, and a final layer of 1/4" plywood on top. For anything wider than 4', you need to frame it out unless you can find 5' wideply.
Here's my framework for a 5' x 10' 'drop.
Those are temporary gussets.
Postby John61CT » Mon Sep 16, 2019 7:54 pm
No, but will save energy if running aircon
John61CT
Postby Minics04 » Tue Sep 17, 2019 6:35 am
I did insulate mine, also.
If you are concerned with moisture under the mattress and are going to use some thing for air flow under your mattress, I would insulate it. I'm not sure moisture is a problem under the mattress, but I wanted a little air flow under the mattress.
Minics04
Postby Shadow Catcher » Wed Sep 25, 2019 7:01 pm
It is a 5" foam mattress ;)
Postby halfdome, Danny » Thu Sep 26, 2019 2:32 pm
LostBob, I too insulated the floor on my first build.
Now my floor is 3/4" plywood with a full sheet of palm glued down on both sides, great barrier to moisture.
If you find the need for insulation in the future just cut two panels of foam board and duct tape the raw edges.
We have used our two 1/2" foam boards on rare occasion by simply sliding them under the mattress.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby tony.latham » Thu Sep 26, 2019 4:23 pm
Here's the real insulation:
8" of foam.
Postby azgreg » Sun Oct 13, 2019 3:23 pm
halfdome, Danny wrote:LostBob, I too insulated the floor on my first build.
:D Danny
Have any more info on the palm?
azgreg
Postby RJ Howell » Sun Oct 13, 2019 4:12 pm
This to me is a basic thing. Cold absorbs heat. It's not a direction thing, it's a absorption thing. I work R-Factores according to what I want warmer. Yes, my floor insulated, I want that extra there. I want to remove blankets to control vs. adding more padding to my mattress. I'm a proponent for making the trailer insulated and making my mattress comfortable. It's how I look at at. MHO
RJ Howell
Images: 36
Postby Pmullen503 » Sun Oct 13, 2019 9:28 pm
You won't regret insulation. I too am in the great lakes region. If your matress covers the entire floor you'll be OK. But some bare floor is at the foot of the mattress or the sides you could get condensation there. Water will condense if any surface is below the dew point. I get it around the door flanges and window frames but not my insulated floor.
Pmullen503
Images: 67
Postby halfdome, Danny » Mon Oct 14, 2019 1:58 pm
:D Danny
plam is plastic laminate aka Formica. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby azgreg » Mon Oct 14, 2019 8:06 pm
halfdome, Danny wrote:plam is plastic laminate aka Formica. :D Danny
You use that instead of slathering on the black crap?
azgreg
Postby halfdome, Danny » Tue Oct 15, 2019 1:58 pm
yes
halfdome, Danny
*Happy Camper
Images: 252
