just remember what an expert is, by breaking down the word.
an ex,,,,,is a has been
and a spert,,, is a drip under preasure.
basic welding machine types are
arc welder, uses ac or dc current to cause an arc that melts the parent metal and the filler rod to join the work. the filler rod,,,or welding rod, is coated with a material (flux) which burns and forms a gas bubble around the weld to protect the molten metal from the atmosphere. to weld you scratch the rod on the serfuce of the metal, then as the arc starts you adjust the gap to maintain a smooth stable arc. with the rod at the proper angle of lead .
flux core (with a flux core......go figure)is a wire feed welder with a gun that automaticly feeds the filler metal into the weld for you. also known as a innershield welder. to weld you simply aim the wire at the seam, squeeze the trigger and draw the gun along like a giant pencil on the seam. speed will become appairent.
mig welder, same machine as the flux core welder, but with solid wire.
instead of flux it uses a shielding gas such as argon, or argon/co2 mix, or pure co2 to protect the weld puddle. this requires a tank of gas, and a regulator to be added to the machine. to weld with this set up you place the wire at the seam, pull the trigger, then push the gun along the seam.
these are most likely the machines you will choose from in a home shop.
an arc welder, once mastered, specialy in a unit with both ac/dc current ability is the most versital. allowing welds on steel, cast iron, aluminium, or almost any metal you run acrossed.
the down side,,,, some skill is required and lots of practice to master it.
if i could have only one machine this is what i would go with. understanding of course i have about 20 years of practice with them.
the majority of you will want something easier to master and thats what the wire feed welders excell at. we old guys swear we could teach a monkey to weld with one,,,,lol.
between the two choices,(really the same machine) the cheapest and easiest is the fluxcore. at least to purchase. BUT, flux core wire is expensive.
that being said. it does a good job and if your not going to do a lot of welding its a good choice. say building one trailer per year or a few repairs. in addition, if you find you use it alot you can always add the tank and regulator as need or finances allow.
ok,,, how much power do you need?
depends on what your working on. most trailer parts are between 1/8 to 1/4 inch thick. the box the welder comes in will tell you how thick it will weld in one pass.
by making multiple passes you can far exceed this. but that takes some learning to do properly. so try for one pass. as with most things we guys like,,,,, more power is always better,lol. usually the cheapest machine at home depot does 1/8, the next machine up will do 1/4 or so. i'd go with the second.
the only other welder that you will come up against would be a tig welder, also known as heliarc. this is an electric torch held in one hand, while the filler metal is added into the weld with the other hand. the weld is shielded with an inert gas like the mig welder. this is the prefered welder for aluminium and stainless steel, and for precision weldments.
i hope this stuff helped someone, if so,,,,my mission is accomplished.
