6x12 aluminum build
Re: 6x12 aluminum build
Postby deceiver » Sun Oct 13, 2019 11:10 am
Mdcamper wrote:The wiring is all for 120v, and it is a cut-up 14g extension cord. Stranded wire is superior for vibration/flexible applications. I am leaving the factory 12v lights which can operate off of my truck batteries, but no battery system in the trailer. 15a breakers on the 14g and then I will have one 20a breaker with 12g wire feeding a receptacle for either the window a/c or electric space heater as necessary.
With this update I can see that you seem to be doing everything right for the type of electrical you're planning. The extension cord thing is a good idea. I've used it in applications myself. A very cost effective use for wiring with stranded wire, especially if you've got a few old long ones lying around that have seen better days.
Not that you need my opinion... just an acknowledgment that I didn't quite understand before, now I do. Looks good.
Conform and be dull.
deceiver
Images: 67
Postby Mdcamper » Sat Nov 09, 2019 8:36 pm
Update: Progress has been a bit slow due to working O/T and other commitments. Insulation done and 1/2" plywood stripping added for an additional thermal barrier. An extra 1/2" of XPS is being installed between plywood strips.
IMG_0129 copy.jpg (256.59 KiB) Viewed 1736 times
IMG_0133 copy.jpg (287.99 KiB) Viewed 1736 times
Mdcamper
Postby Mdcamper » Sat Nov 09, 2019 8:40 pm
Installing T1-11 with 4" O/C grooves on ceiling and walls. I'm leaving the wiring channel at the top of the walls open for now and will cover it with trim to make it accessible without removing any paneling.
IMG_0139 copy.jpg (328.82 KiB) Viewed 1735 times
IMG_0140 copy.jpg (329.12 KiB) Viewed 1735 times
Mdcamper
Postby aggie79 » Sun Nov 10, 2019 7:41 am
Very nice! Great work. :thumbsup: :applause: :thumbsup:
Postby deceiver » Sun Nov 10, 2019 12:11 pm
You went with the good insulation. Should keep things cooler in the heat. I find that I realize I insulated the thing more for the hot than the cool weather. Glad I put the insulation in.
deceiver
Images: 67
