troubleScottie wrote:Assuming it is already constructed, it is difficult to add insulation into walls. If this is just a plywood wall, then no space.
Putting some sort of insulating material inside would help. The question then becomes how much/how thick and how attractive.
Reflectix foil barrier could be used -- but you are living in a aluminum cocoon.
There are fiber equivalents -- less shiny, but still obtrusive.
Carpet placed on walls will take some of the edge off. At least it might feel warmer.
As stated in other response(s), a heater might work. You are heating a small space. In addition, you most likely do not need to get the temperature to 75F or keep it there.
Options include:
small AC heater eg ceramic, quartz, oil based ( obviously need AC shore or running generator )
propane, diesel or gasoline heaters which can be run from batteries (fan, ignition, temp control) eg Espar, Propex, Webasto or Chinese equivalents. Requires fuel and cutting holes.
propane heater like Mr Heater Buddy run for a while to heat the interior and then turned off
more bodies/barn effect. Animals give off heat. It does warm the space around them. Add others, dogs.
Then the simpler is just assume you are 4 season camping in a tent -- warmer sleeping bag(s)/covers/quilts, good/better mattress, wear stocking cap and more clothes.
Cold... Especially in Texas!!!
lfhoward wrote:I’m curious what strategy works best to keep warm...
- Ceiling vent cracked open a bit, windows closed all the way
- Ceiling vent closed, window (or both windows) cracked open a bit
- Ceiling vent cracked open a bit, one window cracked open slightly
The idea is to conserve heat, while allowing for fresh air (a fully closed up camper can kill you). Also, condensation can be an issue in the cold.
Which strategy do you employ? I know if I am plugged in at an RV park and can run my baseboard heater, I keep both the ceiling vent and a window slightly cracked open and it’s still nice and toasty. But I haven’t figured out what works best while boondocking.
