Insulating Properties of Plywood
Postby tyke » Thu Jul 20, 2006 9:34 am
Hi :D
In an effort to simplify my plans I am considering using a single 18mm sheet of ply for my side walls instead of forming a sandwich of 2 pieces of 9mm with insulation.
Would a single sheet of 18mm give enough insulation to stop condensation problems bearing in mind that in this part of the world we don’t get really cold winters or red hot summers.
Steve Topp
tyke
Postby TRAIL-OF-TEARS » Thu Jul 20, 2006 10:03 am
tyke,
I think you will be fine with 18mm. Mine is built with 3/4"(I think that is the same as 18mm) ply, and we have never had a problem with condensation, inside or out. I think if you have good ventilation that will help as well. good luck.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby tyke » Thu Jul 20, 2006 10:42 am
Cheers Steve :D
I was hoping that would be the case :)
Steve Topp
tyke
Postby madjack » Thu Jul 20, 2006 10:46 am
SteveT...we build our tears with 3/4 ply side...to me, the key is adequate ventilation...windows and roof vents.....
madjack 8)
Postby tyke » Fri Jul 21, 2006 3:24 am
Hi Jack :D
I intend to have plenty of ventilation as it will be mostly used in the summer travelling to shooting competitions around England.
Thanks for the reply ;)
Steve Topp
tyke
Postby SteveH » Fri Jul 21, 2006 6:27 am
One thing to keep in mind is, most all of the original teardrops were made with 1/2" side wall, and they seemed to do OK.
SteveH
SteveH
Images: 42
Postby dacrazyrn » Fri Jul 21, 2006 8:27 am
Go through this and you may get more of an answer than you can handle. especially under the heating and insulation part
http://www.1stconnect.com/anozira/SiteT ... struct.htm
dacrazyrn
Images: 74
Postby tyke » Sun Jul 23, 2006 11:25 am
:D Thanks everyone :thumbsup:
Steve Topp
tyke
