I am on a tight schedule as I need to get the walls up and roof on in the next couple of days, Trailer will be tossed out into the cold in three or four days. Wanted the walls and roof up so I could throw a tarp over it.
Hate to say it, but taking the walls down and storing flat till spring may be your best bet.
How do you bolt the floor to the frame?
halfdome, Danny wrote:I bolt the floor to the frame with 3/8" elevator bolts and recess the heads with a spade bit for a flush fit.
I use a washer and a lock tight nut on the frame side.Danny
tony.latham wrote:How do you bolt the floor to the frame?
I lay a bead of PL Premium on the top and side of the floor. I then screw from the exterior sheathing horizontally into the side of the floor, followed by pocket hole screws from the inside to the floor.
printer wrote:halfdome, Danny wrote:I bolt the floor to the frame with 3/8" elevator bolts and recess the heads with a spade bit for a flush fit.
That is pretty much what I was thinking. Might add some adhesive between the floor and frame. I will paint the bottom of the floor first though.
I don't know what you guys talked me into.
