would paint on the underside be enough or something in the hole?"Make sure you apply a sealant around the bolt threads and the hole in your floor.
Don't want your floor to rot out."
printer wrote:There was some irregularities in the frame that I used a belt sander to sand the different pieces flush with each other. But when gluing in the foam I end up with some places where the foam is proud of the wood. I need to get them flush with the wood. Either the foam comes down or I build up the wood and surface flush with the foam.
Why am I building this right now?
printer wrote:Not quite enough difference for a Surform. Sander is kind if messy. Just became real cold outside can't toss it on the deck. A hotwire cutter would really stink up the house. Why am I building this right now?
DaddyJeep wrote:printer wrote:Not quite enough difference for a Surform. Sander is kind if messy. Just became real cold outside can't toss it on the deck. A hotwire cutter would really stink up the house. Why am I building this right now?
Quit being a sissy. Put your coat on, take that thing outside, and get it done.![]()
But it is -10 F out!
